should i get a tune up?
Old May 21, 2007 | 05:29 PM
navysealsnypre's Avatar
Default should i get a tune up?
should i get a tune up, or would it be a big waste of money, itd be on my 94 accord lx with 170,000+ miles.. or is there anything ii can do myself to do my own tune up?
Old May 21, 2007 | 07:24 PM
JimBlake's Avatar
Default Re: should i get a tune up? (navysealsnypre)
You could change the air filter & spark plugs, and clean up (or replace) the plug wires, distributor cap & rotor.
If you have to ask, I suppose you don't have a timing light to check/adjust your spark timing?
All that stuff depends on how long & how many miles since each thing was done last.
Old May 21, 2007 | 08:03 PM
pos_cd5's Avatar
when was the last time it had a tune-up. if you dont know then its probably time for a tune up. its fairly easy to do yourself. go pick up a repair manual such as haynes and go for it. heres a quick list of stuff to replace during a tune-up:
-oil
-oil filter
-transmission fluid
-spark plugs
-dist. cap & rotor
-inspect and replace spark plug wires if there are visible cracks and/or deterioration (OEM honda wires seems to last a pretty long time, so these dont always need replacing, but it wouldnt hurt)
-inspect and replace brakes pads/shoes and rotor/drum if needed
-flush and bleed brake fluid
-flush and refill coolant
-air filter
-cabin filter
-timing belt (should be replaced every 80-100k miles. if in doubt, CHANGE IT!)
if i missed anything or if anyone have anything to add to the list feel free.
Old May 21, 2007 | 08:15 PM
Bruce Banner's Avatar
Default Re: should i get a tune up? (pos_cd5)
maybe valve adjustment
Tuesdaynightfever
May 4, 2008 10:01 AM
Tron 2.0
Aug 13, 2006 03:12 PM
Bluj40
Mar 6, 2006 05:37 PM
ca_delsol
Jul 29, 2005 11:20 AM
Cypher0117
11
Apr 24, 2005 09:26 AM
