93 eg hatch wont
eg hatch wont start i read all the wont start topic did find what i am lookin for. so here we go again. first hatch has ran with ls swap for over 1 year. the ls motor is a 94 but the tranny is 93 cable tranny. well the hatch was starting fine but not to start on frist turn of key. it seemed if the battery was dieing or the starter was going out. it would start after afew turns. then it wouldn't start at all so had to push start it, that worked for afew weeks then it wouldn't start at all. so i replace the starter with a 90 integra starter and new battery. but now it doesn't even turn oveer it just makes a clicking nose under dash. right above fuse box. all fuses are good.
my 92 hatch did the same thing so i had to replace the starter, but i ended up replacing the battery too after the battery it worked fine for like two weeks and then started doing the clicking **** again so i took out a voltmeter and checked the voltage going to the starter it was fine so i checked the starter and found out it was a bad starter so i replaced it and it was all good and well ran like new so maybe you just got a faulty starter just go to pepboys and get a rebuilt one but since you have a honda they are going to ask you if it is nippodenzo or mitsubishi so find that out first before you go to buy one
needhelp///
Apr 28, 2011 08:35 PM
