Which NGK copper spark plugs to use for 95 JRSC b18b 6psi
Old May 21, 2007 | 01:46 PM
fasteddy91's Avatar
Default Which NGK copper spark plugs to use for 95 JRSC b18b 6psi
Hey guys,
Tried searching with mixed results. for those of you using a jackson racing supercharger on a b18b LS. Which NGK sparkplugs should I use? currently I'm using the stock NGK zfr5's and will be installing the charger next week. do i use the NGK BCPR7ES-11, or ZRF7F or BCPRS7ES? What gap is recommended? only boosting 6psi with I/H/E. thanks!
Modified by fasteddy91 at 11:00 PM 5/21/2007
Old May 24, 2007 | 09:13 AM
fasteddy91's Avatar
Default Re: Which NGK copper spark plugs to use for 95 JRSC b18b 6psi (fasteddy91)
found what i needed. I was told to use ngk 6zfr6f-11 with a .044 gap with stock ignition or .032-.035 with msd box.
zojirushi
Jan 10, 2006 09:25 PM
B_1_8_hatch
Apr 4, 2003 02:52 PM
E Swift
Sep 2, 2002 06:46 AM
