Jumpy Idle
Old May 21, 2007 | 01:28 PM
ballerchild's Avatar
Default Jumpy Idle
i'm about to pick up a really clean stock DA today and the only problem it has right now is that the idle jumps from 1k-1500 when stopped and the battery indicator light is on. The seller told me that the battery is new and that the alternator went out on him within a couple days ago. Do you think that a bad alternator would cause this problem? Or what else would be the cause of that?
Old May 21, 2007 | 01:31 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: Jumpy Idle (ballerchild)
A bad power source, ground or alternator, can cause a jumpy idle and thats probably why the battery light is on. If your going to be the one fixing it I would suggest taking the alternator apart because it probably just needs new brushes that are 5 bucks at the parts store instead of buying a new alternator for $100+
Old May 21, 2007 | 01:42 PM
Default Re: Jumpy Idle (St Jimmy)
thanks for the quick reply, i already bought a nice rebuilt alternator for $50. So what else should I check for or I need to replace? I'm gonna be replacing the alternator and belt later today and I wanna make sure I get rid of that problem!
Old May 21, 2007 | 01:49 PM
St Jimmy's Avatar
* B A N N E D *
If it still does that check all your grounds on the battery and the chasis. Then check for vacuum leaks, clean you IACV valve and if it still doesn't stop, youve got issues on your hand
Old May 21, 2007 | 02:18 PM
cool! i'll make sure to check all of that.. thanks for all the help, i'm hoping that all it is is the alternator issue
jauldredge
Jul 22, 2008 06:40 AM
SupraRXZ
Mar 20, 2007 07:52 AM
pstutz
Apr 26, 2003 12:05 PM
boonacka
Jan 27, 2003 01:24 PM
crxtreme27
11
Aug 28, 2002 11:29 AM
