when putting in new pistons..
Old May 21, 2007 | 12:30 PM
Prudz_lude's Avatar
Default when putting in new pistons..
from what i have learned on honda-tech is that the sleeves used in the h22 are frm. they are not the weak point of the block, its the ringlands that give out. If i bought a new set of pistons slightly larger with some new rods and ringlands could i just bore the stock sleeves slightly larger? does it make the block weaker? If i did bore the block out slightly so that i could put new pistons, rods, and ringlands in without sending my block away could the block still handle about 250whp?
Old May 21, 2007 | 12:37 PM
nonvteclude's Avatar
Default Re: when putting in new pistons.. (Prudz_lude)
what pistons did you buy?
Old May 21, 2007 | 12:39 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote">from what i have learned on honda-tech is that the sleeves used in the h22 are frm. they are not the weak point of the block, its the ringlands that give out. If i bought a new set of pistons slightly larger with some new rods and ringlands could i just bore the stock sleeves slightly larger? does it make the block weaker? If i did bore the block out slightly so that i could put new pistons, rods, and ringlands in without sending my block away could the block still handle about 250whp?</TD></TR></TABLE>
ringlands are part of the piston
Old May 21, 2007 | 12:41 PM
Prudz_lude's Avatar
Default Re: when putting in new pistons.. (lude98SH)
^really i had no clue, i always thought it was a seperate part. I am still a noob so bare with me. I did not buy any yet this is why i am asking.
Old May 21, 2007 | 12:45 PM
lude98SH's Avatar
yes its the area between where the rings sit
Old May 21, 2007 | 12:48 PM
Prudz_lude's Avatar
my bad. Ok well then i meant to say rings. anyway back to the real question. Can the stock sleeves be bored out a little more and still be safe?
Old May 21, 2007 | 12:50 PM
lude98SH's Avatar
well honda makes OS pistons so yes. But im not the most knowledgable person on this matter so lets see what everyone else has to say.
cluelessmale
May 28, 2007 07:43 PM
evade this honda
Jul 28, 2006 07:20 PM
Maddox
Jun 6, 2004 08:53 AM
b_jamin
Mar 19, 2004 02:55 AM
Howitt
Sep 25, 2002 03:28 PM
