Repainting bumpers
Old May 21, 2007 | 12:13 PM
Finest's Avatar
Default Repainting bumpers
Is there anything special that needs to be done to repaint bumpers? It's just a stock OEM bumper, but it's silver. My car is white. Any tips or tricks to keep the paint flexible and not crack over time?
Old May 21, 2007 | 12:31 PM
WihaSi's Avatar
Default Re: Repainting bumpers (Finest)
Basically just go over the bumper, repair and scratches or chips. Use plastic repair material, primer filler on repair areas. Sand primer filler down (600/800 wet, either or). Scuff the entire bumper down, wash, dry bumper. Then paint your bumper, and don't forget flex additive. If you need me to go into better detail just ask
Old May 21, 2007 | 12:35 PM
Finest's Avatar
Default Re: Repainting bumpers (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote"> and don't forget flex additive. </TD></TR></TABLE>
That's what I keep on hearing, to add a flex additive. Do I have to mix it in with the base and/or clear? Thanks again!
Old May 21, 2007 | 12:38 PM
WihaSi's Avatar
Yup you just mix it in. When I sprayed DuPont they suggested mixing it in with your base coat also. Basically it's just a cap full of additive per 10oz of paint, if I remember correctly.
Old May 21, 2007 | 01:34 PM
powerflow's Avatar
^^good info...The paint system I use mostly, recommends the flex in the primer also. Using quality automotive paint would make a long lasting finish. As long as the current finish on the part is adhering good your golden.
SLO Sol
Paint and Body
Sep 26, 2007 10:59 AM
Bend My Rods
May 5, 2007 03:08 PM
hks369
Paint and Body
May 4, 2007 11:10 PM
Kirk@SyndromeAuto
Mar 16, 2005 11:14 AM
B18ls*RAYON
Jan 17, 2005 12:04 AM
