93 hatcback deck removal
Old May 21, 2007 | 12:03 PM
r3sgtec's Avatar
Default 93 hatcback deck removal
I have a 1993 civic hatchback with a broken antenna. I know how to install the antenna, however, i dont know where the screws and tabs and stuff are to remove the deck to unplug the antenna. i dont want to crack any of my dash parts, so does anyone know how to remove the deck properly?
Old May 21, 2007 | 12:29 PM
spawnd's Avatar
Default Re: 93 hatcback deck removal (r3sgtec)
hope this helps
https://honda-tech.com/zerothread?id=661308
Old May 21, 2007 | 12:34 PM
instructor74's Avatar
is it factory or aftermarket it makes a world of differance on how the release mech works
Old May 21, 2007 | 12:50 PM
r3sgtec's Avatar
Default Re: 93 hatcback deck removal (instructor74)
its has an aftermarket deck in there right now, just cant figure it out. i did it like the link above, but deck doesnt "sort slip out" like that right up did.
Old May 21, 2007 | 02:38 PM
r3sgtec's Avatar
can anyone help???
Old May 22, 2007 | 05:14 AM
Sounds like it's time to go to a stereo shop and have them remove it for you. Most of the aftermarket radios have there own locking mech to hold the deck in the cage. With out the tool to remove it or knowing where the lock mech is and how it works you might brake things trying to get it out. Just pay someone the $20 to remove it for you.
Old May 22, 2007 | 01:26 PM
NOFX's Avatar
H-T White Ops
http://www.installdr.com
Old May 22, 2007 | 01:32 PM
sohczcturbo's Avatar
Default Re: (NOFX)
Most brands use their own style of locking mechanism. When you buy a deck new it usually comes with two keys (one for each lock on each side of the deck) that release it. However not everyone gets new decks, so I figured out a little secret. I uses hack saw blades as keys and it actually works for most decks I've tried it on. Just be carefully not to actually cut anything like the stereo din or the wiring harness. Also with my hatch I found that if I remove the center console (right under the stero) and can look up and pry the locking tabs out with a jewlers flat head screw driver or a dental pick tool. Hope this helps But Instructors idea is probably best, and then you could maybe order the right keys for that deck. They can't be more than a few bucks considering they're just stamped tin metal.
sergeant dukesalot
Audio / Security / Video
Jun 7, 2009 04:54 AM
EdoMoto
Acura TSX
Aug 15, 2008 08:07 AM
RemoveGiantWingOnYourCar
Apr 4, 2007 05:57 AM
friscorice88
Dec 13, 2005 08:40 PM
