about 20-30 trq and whp loss on bone stock jdm itr in 1900lbs eg cx hatch?
About 20-30 trq and whp loss on bone stock jdm itr in 1900lbs eg cx hatch? first 2 weeks i had car been running so good i ran 8.5 on 1/8 mile on poor 2.0 60ft. i told myself not going back to lsv or b20v for a long time. buddy that sold me car said im just getting used to the power" and that he did a new timing belt and water pump and spark plugs. so ill i did was a change oil,(moble1 10w-30 full synthec) since then the power and drive-ability loss no smoke or sputters no sign on motor externally. what do you guys think about the hp and trq loss?
Modified by jj's type r at 9:22 PM 5/22/2007
if you haven't dyno'd the car then you don't know if you have actually lost any power!
your butt dyno is NOT accurate at all!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj’s type r »</TD></TR><TR><TD CLASS="quote">"my butt dyno feels a 20-30 trq and whp loss" 4reals!!!!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">your butt dyno is NOT accurate at all!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">damn. that's sucks.
it's time for some turbo now </TD></TR></TABLE>
or some NAWZZZ
or some NAWZZZ
...because everyone in the ITR forum knows about power loss on a JDM ITR motor in an EG hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj’s type r »</TD></TR><TR><TD CLASS="quote">About 20-30 trq and whp loss on bone stock jdm itr in 1900lbs eg cx hatch? first 2 weeks i had car been running so good i ran 8.5 on 1/8 mile on poor 2.0 60ft. i told myself not going back to lsv or b20v for a long time. buddy that sold me car said im just getting used to the power" and that he did a new timing belt and water pump and spark plugs. so ill i did was a change oil,(moble1 10w-30 full synthec) since then the power and drive-ability loss no smoke or sputters no sign on motor externally. what do you guys think about the hp and trq loss?</TD></TR></TABLE>
.....so if you touched the timing belt and spark plugs then it's possible the belt is off a tooth or that you have the plug wires going to the wrong plugs (wrong firing order)..... also make sure you have enough oil because low oil = no vtec.
and please try to be more coherent in your posts, it was quite difficult to glean the gist!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">wow you are 26 and type like a child...
you are assuming that he used his real birth date. You can enter anything you want.
</TD></TR></TABLE>you are assuming that he used his real birth date. You can enter anything you want.
compression test results. cylinders 1-2-3 are at 180 and cylinder 4 is at 200 psi.
when motor was running strong last week im pretty sure they were all over 225psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jj’s type r »</TD></TR><TR><TD CLASS="quote">compression test results. cylinders 1-2-3 are at 180 and cylinder 4 is at 200 psi.
when motor was running strong last week im pretty sure they were all over 225psi.</TD></TR></TABLE>
Might I suggest that the timing belt was not re-installed correctly.
DSMAddicted
21
Jun 12, 2008 03:05 PM
jj's type r
20
May 23, 2007 08:48 AM
jj's type r
May 20, 2007 09:32 PM
