Setting timing on H22A with Advance Timing Light
Old May 21, 2007 | 09:05 AM
pcguy760's Avatar
Default Setting timing on H22A with Advance Timing Light
I have an aftermarket flywheel and I was only able to put a white mark on it for TDC (No. 1 Piston at TDC). So I got an advancing timing light that reads 0 to 60 Degrees and I need to confirm if I am doing this correctly ...
1. Make sure car is at proper idle and temperature.]
2. Jump Service Connector
3. Set advance timing light to 15 degrees (Since H22A stock timing is 15 BTDC???)
4. Point light at flywheel and line up arrow/notch on block with my TDC mark I made on the flywheel.
That's it - is my procedure correct? Also, how come these timing lights are called "Advance" timing lights but I am using it to set my timing to 15 BTDC when I set the light to 15 Degrees?? Kinda confused by that...
Old May 21, 2007 | 07:02 PM
pcguy760's Avatar
Default Re: Setting timing on H22A with Advance Timing Light (pcguy760)
bump?
Old May 22, 2007 | 04:41 AM
pcguy760's Avatar
Old May 22, 2007 | 07:01 PM
pcguy760's Avatar
Wow, does anyone know? LOL.
95EG2
Jun 3, 2011 07:11 PM
pcguy760
May 22, 2007 09:50 PM
pcguy760
May 21, 2007 07:53 AM
hondapwr
May 8, 2006 08:17 AM
AggAccord03
Jul 7, 2004 06:16 AM
