Cheapest way to raise fuel cut with OBD-II
Old May 21, 2007 | 08:35 AM
Aquafina's Avatar
Default Cheapest way to raise fuel cut with OBD-II
Need to raise the fuel cut from 7,200 to 7,500 on a OBD-II Civic EX. Any way I can do this on the cheap?
Old May 21, 2007 | 09:01 AM
Relic1's Avatar
Is 300 rpm is going to make that much of a difference?
direct answer, there isn't a cheap way of doing it that I know of. Chipped/tuned OBD1 ECU would be your best bet.
Old May 21, 2007 | 09:50 AM
Aquafina's Avatar
Default Re: (Relic1)
116mph to 121mph, 116mph top speed is no good at VIR
Old May 21, 2007 | 02:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: Cheapest way to raise fuel cut with OBD-II (Aquafina)
There really isn't a low-budget approach to doing what you're looking for. You can pick up a cheap OBD-1 ECU, chip it, and then burn (or order) a chip with a higher fuel cut. Another option would be to run tires that are a bit larger in overall diameter. This would raise your top speed at the expense of acceleration, the same way using a taller final drive would.
Old May 21, 2007 | 06:18 PM
Aquafina's Avatar
Default Re: Cheapest way to raise fuel cut with OBD-II (Padawan)
Tires aren't an option.
I guess I'll just get a Z6 ECU and order a Boomslang harness and have the ECU socketed and have Rocket make a chip for me. Run on...
efhatch_311
Mar 1, 2010 01:04 AM
fdjizm
Nov 29, 2006 02:32 PM
planomatt
Feb 16, 2005 08:39 AM
93LSivic
Feb 4, 2002 08:35 AM
ringgold
Jul 17, 2001 04:23 AM
