Popping and sputtering
Old May 21, 2007 | 03:34 AM
Got Snail 2's Avatar
Default Popping and sputtering
hey i just sent my head out to get shaved and pressure checked and i got it back and i put arp head studs on and cometic head gasket i have a d16 turbo setup and i also put pro d series intake mani on it and when i went to start it back up today it ran like crap it was like popping and sputtering and not idleing correct jsut low and rough anyone have ideas mabye timing or something i am almost posative i set it correct. all help is apreciated thanks!
Old May 21, 2007 | 04:36 AM
Frozen E's Avatar
H-T White Ops
Valve adjustment?
You get the timing belt back on the right cogs? If you're off by one it'll idle and run like crap. Check the ignition timing as well.
Old May 21, 2007 | 04:52 AM
juevi's Avatar
Foreign Symbols
Default Re: Popping and sputtering (Got Snail 2)
Check for vacuum leaks first. Double check your cam timing.
Old May 21, 2007 | 06:23 AM
Default Re: (IslandSi)
does that sound like a blown head gaskett? its new i think i might just check the timing again and also check for vacum leakes any other ideas what should the crank pully be lined up with?
Old May 21, 2007 | 06:27 AM
juevi's Avatar
Foreign Symbols
Default Re: (Got Snail 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">does that sound like a blown head gaskett? its new i think i might just check the timing again and also check for vacum leakes any other ideas what should the crank pully be lined up with?
Well, if your not sure about the timing marks, that should be the FIRST thing you do. Do a search for timing marks or hit up the FAQ section. Get the cam timing right first, and then let us know.
Frozen E's Avatar
H-T White Ops
There's a mark on the pulley and a mark on the lower cover. They should line up. The lines on the cam gear should be even with the surface of the head.
Old May 21, 2007 | 08:03 AM
Default Re: (juevi)
ok thanks man
Old May 21, 2007 | 03:00 PM
Crispy's Avatar
Just tossing it out there.... maybe a plug not gapped right, I had one that slipped off the ratchet and banged the electrode on the way in, I didnt think anything of it but it caused a rough/popping idle until I replaced it.
Old May 22, 2007 | 03:53 AM
Default Re: (Crispy)
haha that is exacty what happended lol i was pulling off the wires wile it was running to see if it would bogg out and it bogged out on all three and then on the 4th cylinder it ran the same when i pulled the wire off so i popped out the plug and the gap was closed so i re gapped it and it ran fine lol and the whole time i was thinking that they touched my valves when i sent it out to get my head shaved and pressure checked... when i was a stupid plug i must have dropped it or something when intalizing. thanks for everyones help i appreciate it.
TachiKun
Mar 28, 2016 11:28 AM
drpepper123
Engine Management and Tuning
Mar 29, 2011 03:45 AM
drmix
May 27, 2008 09:25 PM
petarr
Apr 7, 2006 10:11 PM
