B18C JDM gsr into a 96 civic dx post swap issues please help!!!
ok so i've done all the wiring using katman's diagram and to my knowledge it is all correct and that is my problem i cant get it started...from the beginning w/ the started that came w/ my motor i turned the key the first time after everything was reconnected i get one click no turn nothing else...second time i turn the key nothing other than the starter relay in the ecu...then put in my friends starter off his b16 first turn of the key it starts turning over i stop to give it a lil brake and the next time i turn the key NOTHING AGAIN no turn no noise other than the relay in the ecu...
IF ANYONE HAS ANY ADVICE PLEASE!!!! TELL ME, thanks
me and friend just swapped a b16 in his ek, and we had similar trouble... we had the starter tested 3 different times, and after searching on h-t, i decided to check all my ground wires, which it ended up being.
EracerUgone
Nov 28, 2011 04:02 PM
98bucket
Jun 4, 2011 03:13 PM
