R18 Oil Leak
Just wondering if any other techs that work at Honda Dealerships have seen any non-Si civics coming in with average mileage and an obvious oil leak which would appear to be a leaking rear main seal, common on higher milage D series motors. I have personally come across 3 where this has been the case. There is a technical service bulletin out regarding this problem and it requires replacing an oil seal plug and crush washer in the rear of the engine block and the rear main seal as a precaution because the transmission has to be removed to access the seal plug. The plug has been the culprit for the oil leaks so far, apparently they were not properly torqued when the engines were being manufactured. I am sure that this problem has been rectified through Honda since the release of the TSB, but I am unsure if VIN serial codes have been identified on the TSB as to which vehicles are possibly affected. I will look up the TSB at work this week and post more information. Just looking out for any dealerships that may or may not want to advise warranty work.
The last 2 times i changed my oil my car had only drained 1 and 1/2 quarts out. Ya sounds crazy, i was 2.5 quarts low both times. I neve seen any leaks on my driveway so i wasnt sure wat was goin on. Im startin to monitor my oil now, I checked it after about 1k mile after my last oil changed, it seemd alittle low but hard to tell with the dipstick. I plan on changin the oil next month, i hope more then 1.5 quarts comes out
well if your car was leaking oil like I have seen due to this problem, the entire bottom of the transmission would be covered in oil, sometimes it leaks so much it even coats the exhaust and subframe mount.
hmmmm, i got my oil changed a couple of days ago. the dude that did it said i had a small oil leak and that i should get the dealership to check it out. i've put about a little over 5k on my car now. i also haven't seen any oil marks on the ground. should i be worried?
Not a bad idea, my friend did that with a caddy once, except he drained all the oil out first then let it run. Took about a hour i think before it blew. Then he put the oil back and called the dealer. They put a new motor in it lol, car had about 80k. miles on it, still under warrenty. Dealer said the oil pump went bad or something. lol
VEHICLES AFFECTED
2006 Civic
4-Door – From VIN 1HGFA1...6L000001 thru 1HGFA1...6L058027
From VIN 2HGFA1...6H500001 thru 2HGFA1...6H505400
From VIN JHMFA1...6S000001 thru JHMFA1...6S005042
2-Door – From VIN 2HGFG1...6H500001 thru 2HGFG1...6H523216
2006 Civic
Only seen one 06 civic with a leak from the plug behind the trans. Havent seen any of the other plugs in the bulletin leak, but have had many come in with the power steering leak from the inlet pipe.
I noticed a small oil leak just a day or two after an oil change, I put it on the lift and it was the Honda filter that was leaking. Had Honda put a new one on, and two days later still leakings from gasket in oil filter. I bought one (a filter) and it seems like the gasket/seal around the top is "iffy". It moves around too much and has too much play. Put an aftermarket filter that had a much better seal, and PRESTO! No more oil leak. Maybe not the same issue, but I'd watch out for that JIC.
