Single stage VS. Base/clear color match?
Old May 20, 2007 | 05:08 PM
iceman7329's Avatar
Default Single stage VS. Base/clear color match?
Im going to jam the LX next week, its going to be long beach blue pearl. If I use a single stage urethane paint on the jams how will the color match be when I use base/clear on the rest of the car? Shouldnt be to noticable right?
Old May 20, 2007 | 07:47 PM
powerflow's Avatar
Default Re: Single stage VS. Base/clear color match? (iceman7329)
Whats "noticeable" is more of an opinion, witch varies from person to person. The best way to answer your question would be to do a spray out test of each method, and compare. Each spray out should be done in the exact conditions relating to how the job will be painted. Using a 2 stage method on the jams wouldn't take much more time and would yield a good match. Honestly you should be fine, but there is many variables, including how picky you are about the car.
Old May 20, 2007 | 07:52 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Single stage VS. Base/clear color match? (powerflow)
factory paint only has clearcoat on the outside panels....so I would say you are fine
Old May 20, 2007 | 07:53 PM
iceman7329's Avatar
Default Re: Single stage VS. Base/clear color match? (E-Rok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok &raquo;</TD></TR><TR><TD CLASS="quote">factory paint only has clearcoat on the outside panels....so I would say you are fine</TD></TR></TABLE>
I didnt think about that. Guess Ill try it and see.
Old May 20, 2007 | 07:58 PM
powerflow's Avatar
Thats not true on all cars, some factory production cars have one light coat of clear on the inside door jams. Factory paint doesn't always match perfect either.
JDMDB8707
Paint and Body
Mar 14, 2008 08:00 PM
racebucket_eg
Paint and Body
45
Nov 9, 2007 04:14 PM
tommy.
Paint and Body
Aug 25, 2007 03:02 PM
mr. goodwrench
Paint and Body
May 19, 2007 07:49 AM
Adampops
May 17, 2002 05:01 AM
