what do you guys think of my new 88 civic interior!! also have question about E-test pass
Old May 20, 2007 | 11:51 AM
danno33's Avatar
Default what do you guys think of my new 88 civic interior!! also have question about E-test pass
Before PIcs
I didnt have another after pic but i got one that is similar to what my car looked like...mine was actually worse...
After pics everything black even a sued roof! new molded carpet off ebay! no mats looks clean to me
integra dash ! gotta get a black arm rest though
a kinda customized the climat control as well, i just set it on defrost and have the power on and off, its all i need cause its a summer car only..and i think it looks cleaner without all the other stuff colourful climan stuff...Ac and power steering is out for weight...
ebay seats 400cnd for both
re did the door panels and all other panels in the car black
Modified by danno33 at 1:03 PM 5/20/2007
Old May 20, 2007 | 12:08 PM
danno33's Avatar
Default Re: what do you guys think of my new 88 civic interior!! also have question about E-test pass (danno
My e-test question is...well that i cant pass one and im trying everything, i have access to a e test booth so i can keep trying until i pass but it still wont pass, iv tried removing vacuum lines and everything, 91 gas too...what could i do to ensure a pass???...and how do i know if its the cat or not? i dont want to change that and findo ut that i didnt need one...thanks for the replay guys!
Old May 20, 2007 | 01:42 PM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danno33 &raquo;</TD></TR><TR><TD CLASS="quote"> iv tried removing vacuum lines and everything, 91 gas too...</TD></TR></TABLE>
what????
how does removing vacuum lines do anything good?
running 91 octain will make the results worse.
the sedan steering wheel looks much better then the one in the after pictures..
Old May 20, 2007 | 02:16 PM
No2Pencil's Avatar
NICE man... what i wanted to do.. did you have to buy seat mounts?
Old May 20, 2007 | 02:21 PM
stemiched's Avatar
i as well like the before steering wheel.
also like the climate control being stock, unless it was cracked or something along those lines
and get yourself a speedo with a tach.
other than that it looks good and i must say good job
now post up pics after it sits in the sun and the paint cracks/fades
Old May 20, 2007 | 02:54 PM
abnaasefmb's Avatar
i really like it, i would like to see the headliner. here is a couple of knitpicks, i dont like the shift **** and i don't like the stock steering wheel. but over all really nice.
Old May 20, 2007 | 03:31 PM
danno33's Avatar
i am definitely changing the wheel 100%, i wanted a newer stock honda wheel, a fat one with a push horn instead of button..i am also going to be changing the **** it is temporary jsut so i can drive the dam thing..lol this thing is still a working progress. but i want this thing to look clean and NOT flashy and ricey...just a nice stock look but completely different from Oem..
i had already installed a digital tach where the vent is on the drivers side, i modified the vent so it fits clean and flush...i will post pics of that as well, dont know why i didnt lol
the paint shouldnt crack at all it wasnt a normal spray can it was vinyl dye so it should hold on for a bit.
the seat: i had to order seat brackets, and modify those seat brackets to fit these seats, they were a bitch...
i will get pics of the black overhead as well....
Old May 20, 2007 | 05:09 PM
welfarepc's Avatar
so you just sprayed vinyl dye over the dash and door pannels? how did it bond to plastic pieces? looks good in the pics
Old May 20, 2007 | 05:29 PM
hon da top's Avatar
clean
Old May 20, 2007 | 06:06 PM
J4k3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danno33 &raquo;</TD></TR><TR><TD CLASS="quote">i am definitely changing the wheel 100%, i wanted a newer stock honda wheel, a fat one with a push horn instead of button..i am also going to be changing the **** it is temporary jsut so i can drive the dam thing..lol this thing is still a working progress. but i want this thing to look clean and NOT flashy and ricey...just a nice stock look but completely different from Oem..
i will get pics of the black overhead as well....</TD></TR></TABLE>
Some of those seats came with my car. The only difference was the stiching was red. I tried for about an hour to install them and figured stock was fine for me.
Old May 21, 2007 | 10:44 AM
danno33's Avatar
well i took everything out of the car, it was completely gutted...so i had a chance to use plastic paint of plastic pieces and vinyl dye of the vinyl pieces...simple...it is ligit too it looks stock, not like a crappy paint job...
Old May 21, 2007 | 11:24 AM
dandizel's Avatar
what are your emission readings? A quick and easy way to check your catalytic converter is to get under the car and bang on it, you should not hear anything move. If you do hear **** in there then most likely the contents inside have broken up therefore it clogs your exhaust system causing a missfire/bad gas mileage and so on. Pay reallly close attention when your bangin on it because rocks/debree can get inside the heat shield and make it seem like material has broken down inside the cat, yet its just inside the heat shield. Good luck
Old May 26, 2007 | 05:43 PM
welfarepc's Avatar
Old May 26, 2007 | 06:56 PM
~sp33~'s Avatar
EFB055
lol @ it turning into a crx dash halfway through. I like the seats and it looks clean. You also have the same cd player as me
Old May 26, 2007 | 08:02 PM
Blanket Jackson's Avatar
I like the all black interior!! Looks really good.
Old Jun 9, 2007 | 01:00 PM
danno33's Avatar
ahah yea i sjut tried to find an identical picutre of what my car used to like similar too...haha that was the closest one....the first pic is real though lol
Old Jun 9, 2007 | 03:09 PM
TougeOnly's Avatar
yeah,looks pretty decent
Old Jun 9, 2007 | 04:54 PM
bigluelok's Avatar
It looks good
Old Jun 9, 2007 | 04:56 PM
Malgerus's Avatar
Nice interior. Can I see a pic of the whole car?
Old Jun 28, 2007 | 11:26 AM
TougeOnly's Avatar
by the way,the integra dash fit straight there or you need to cut some plastic?
Old Jun 28, 2007 | 03:03 PM
michael O's Avatar
looks clean.
Old Jun 28, 2007 | 03:18 PM
Hotori Hanso's Avatar
that looks very very nice. its any civic owners nirvana .
how much did the whole restoration cost?
cappa
Mar 27, 2013 01:05 PM
Rev2 9K
Acura TSX
Mar 23, 2007 10:17 AM
JDM_d15b_eg8
Mar 8, 2007 04:47 PM
Downey
Sep 5, 2003 08:25 AM
