Poorman's R with GSR Head?
Old May 20, 2007 | 11:09 AM
TealEG!'s Avatar
Default Poorman's R with GSR Head?
I am planning on turning my GSR into a poorman's R but plan on keeping the GSR Head. I want to use jdm itr pistons, R cams, Ferrea valvetrain, and skunk 2 manifold. so basically besides the difference in the head it will be a type r. my question is will i be able to safely run a type R ecu with this setup since the head is slightly different or will it not matter. also what are the differences in the r cams. are all us R cams the same and are they the same a jdm ones. i heard that jdm 00-01 are different. not sure which ones i want to run yet. thanks.
Old May 20, 2007 | 11:17 AM
pr0honda's Avatar
Default Re: Poorman's R with GSR Head? (TealEG!)
you can run that ecu no problem i would suggest getting something tunable though.... your compression will be higher than that of a typer engine due to the smaller chambers of the gsr head. the 00 or newer r cams are all the same.
shawn
Old May 20, 2007 | 02:19 PM
TealEG!'s Avatar
Default Re: Poorman's R with GSR Head? (pr0honda)
thanks for the reply. and also are does it matter if its us or jdm for the 00-01 cams. so are you saying us 00 r cams are different from 97 us r cams?
Old May 20, 2007 | 08:50 PM
blacK_Dc4's Avatar
"Poorman's R" = B16 head + b18c1 block
The only difference between the ITR cams are that the 00-01 have 3 more degree of duration on the intake side.
Old May 20, 2007 | 10:06 PM
1.8L_allmotormilitia's Avatar
no point with gsr head. poormans itr is b16 head just how black_dc4 listed.
Old May 21, 2007 | 04:54 AM
IntegraType-R's Avatar
your better off supaing that gsr up then doing a poor mans R..even then with a poor mans R you lose compression because of the b16 head....and ya..glhf with that.
Old May 21, 2007 | 07:18 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
i have a good idea get a real b16b head and get itr pistons ! that **** will b very nice ! garenteed ull like ! but i ask how much ?
Old May 21, 2007 | 08:13 AM
jkeno112's Avatar
Default Re:
that just defeats the purpose of it being a poorman's R if you just have a gsr block with a gsr head.
you can simply just sell the Gsr head and pickup a b16 head and build those internals up. its cheaper and will make that motor a Poorman's Type R. just my .02
Old May 21, 2007 | 01:36 PM
TealEG!'s Avatar
Default Re: Re: (jkeno112)
i understand that a poormans r is with a b16 head but thats not what i was asking. i just wanted to know if a type r ecu would be ok to use with this setup since i will be using a gsr head. and i dont see the purpose in selling my gsr head to make an iconvenience to myself and end up losing compression? there is no gain in getting a b16 head.
Old May 21, 2007 | 01:50 PM
projectTeG's Avatar
Default Re: (RED_90TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RED_90TEG &raquo;</TD></TR><TR><TD CLASS="quote">i have a good idea get a real b16b head and get itr pistons ! that **** will b very nice ! garenteed ull like ! but i ask how much ? </TD></TR></TABLE>
b16b's and b18cr's have the same heads.
SR20S13
Feb 23, 2010 06:27 PM
racehesh
Dec 8, 2007 09:32 AM
LyveMyche
Jul 31, 2007 10:07 AM
mushroom281
Jul 12, 2007 07:13 AM
92HB_HB
Dec 19, 2003 08:46 AM
