OBD0 to OBD1 conversion problems
Old May 20, 2007 | 10:48 AM
neofreak's Avatar
Default OBD0 to OBD1 conversion problems
alright so this is really bothering me.
i did a OBD0 to OBD1 conversion yesterday. i used a Boomslang harness and a P28 chipped ECU (ecu is for an auto). i'm throwin codes 14 (IACV) 19 (transmission lockup) and 20 (electrical load detector). i went in with crome and disable ELD and that code went away. i've always had a code 14 even though ti works just fine and i know i'm ont gonna be able to get rid of 19 since i have a auto ecu.
well the biggest problem is now the car sounds like a WRX. #1 is dead. i'm not gettin any fuel to #1. ran the car for a while pulled a plug and it was totally dry. swapped out injectors for a known good injector from a friends car and still nothing. checked continuity of the injector harness (clip to ECU) and it has continuity.
i've searched and searched and searched and i cant find anything.
i have a strong feeling i'm overlooking something simple.
i didnt wire up Knock or Vtec pressure
i could really use some help
Modified by neofreak at 7:17 PM 5/20/2007
Old May 20, 2007 | 02:18 PM
neofreak's Avatar
Default Re: OBD0 to OBD1 conversion problems (neofreak)
anyone?
Old May 20, 2007 | 06:17 PM
neofreak's Avatar
up again.
made a mistake it was #1 not #4
MonkeyParty
May 6, 2014 02:04 PM
waspcrx19
15
Apr 9, 2011 02:28 PM
neofreak
May 20, 2007 06:16 PM
ivanson
Oct 19, 2006 10:56 PM
kyden
Nov 19, 2004 10:45 PM
