Bleed Cooling System
Old May 20, 2007 | 09:44 AM
prayalot's Avatar
Default Bleed Cooling System
Installed new radiator yesterday on my 99 Civic and tried to bleed cooling system.
Tried method in store bought service manual, either I misunderstood part of it or it's wrong. It says to remove thermostat housing, turn heater switch on, turn thermostat 1/2 turn to let breather pin come out, pour in coolant until steady stream comes out around pin. Didn't work. Is there a another way?
I appreciate you time and patience.
Old May 20, 2007 | 01:46 PM
prayalot's Avatar
Default Re: Bleed Cooling System (prayalot)
Got it. Took a fresh look, and of course prayed about it. Just followed same directions from above posting. No problems after two hour test drive.
Old May 31, 2007 | 08:20 PM
notfast@all's Avatar
hey man did you try running or turning on your carbefore you bled the system? what did your car do?
Old May 31, 2007 | 08:24 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
Default Re: Bleed Cooling System (notfast@all)
just let the coolant purge while hAving the heater on at full blast.
Old May 31, 2007 | 09:31 PM
Default Re: Bleed Cooling System (EM1SiR85)
i just wanna know what your car did before you purged it cus my car is acting dumb right now and some guy told me i might need to purge it.
Old May 31, 2007 | 09:52 PM
hondamark35's Avatar
in my experience if you don't see a bleed valve on a honda the just put a funnel on the rad filler neck and fill it with coolant, run it till its hot and give the upper hose a squeze between reving the motor a bit.
some accords have bleeder screws on the thermo housing and some civics have it on the upper hose fitting at the head. but most will work the air out normally the way the honda engineers desgined them
Old May 31, 2007 | 10:02 PM
Default Re: Bleed Cooling System (hondamark35)
but i cannot run it till its hot cus it wont even stay on supposedly cus it needs purging
Old Jun 1, 2007 | 10:38 AM
you mean the engine won't stay running..? that would have nothing to do with the coolant needing purging. you can run it with no coolant in it if you want to burn it up but it'll still run.
check all your wires around the thermo housing where you've been working. there is a ground strap there on some motors and you can have some screwy problems if it's left loose.
Old Jun 3, 2007 | 11:51 AM
hey thanks man, that ground strap you mentioned did have something to do in my car going crazy, its interesting how one stupid little cable can mean that much. it was that and my thermostat
Old Jun 3, 2007 | 12:15 PM
Syndacate's Avatar
just fill it almost all teh way up - and run it w/ the cap off while squeezing the upper rad hose, the air will come out the filler cap hole easy.
EK9JSPEC
12
Sep 1, 2012 08:51 AM
irideslammed5021
Aug 29, 2006 07:47 AM
Gloomyz
Nov 1, 2004 05:16 PM
hbkxtbone
Jun 22, 2004 08:07 AM
