engine type
Old May 20, 2007 | 09:23 AM
globy123's Avatar
Default engine type
What's the easiest way to find out what kind of engine you have in Honda Civic (D16Y7, D16Y8, D16Y5, etc)?
Old May 20, 2007 | 09:25 AM
crispy93's Avatar
look at the stamp on the block
Old May 20, 2007 | 09:26 AM
globy123's Avatar
Default Re: (crispy93)
Where is the stamp located? Which side?
Old May 20, 2007 | 09:27 AM
crispy93's Avatar
its towards the passenger side. what kind of civic do you have?
Old May 20, 2007 | 09:28 AM
Felliph3's Avatar
Default Re: engine type (globy123)
Look in the block,it will be stamped there.
Old May 20, 2007 | 09:32 AM
globy123's Avatar
I have a 99 Civic EX
Old May 20, 2007 | 09:33 AM
Felliph3's Avatar
Default Re: (globy123)
you have a D16Y8
Old May 20, 2007 | 10:12 AM
97Ej6mike's Avatar
https://honda-tech.com/zerothread/878010
that should help, read that thoroughly.
Old May 20, 2007 | 03:14 PM
globy123's Avatar
Default Re: (Felliph3)
the stamp says it's a D16Y7 engine..which are better D16Y7 or D16Y8?
Modified by globy123 at 4:55 PM 5/20/2007
Old May 20, 2007 | 03:15 PM
crispy93's Avatar
you sure its an ex?
Old May 20, 2007 | 03:17 PM
JDM EJ2's Avatar
Someone blew an engine or swapped the badges before you got it
Old May 20, 2007 | 03:18 PM
crispy93's Avatar
that sucks
Old May 20, 2007 | 03:59 PM
globy123's Avatar
The manual says Civic ex but the car is a 4door sedan so I'm guessing it's not an ex. It would be LX then. RIght?
Modified by globy123 at 5:59 PM 5/20/2007
Old May 20, 2007 | 04:07 PM
Libertariat's Avatar
Ek Forever y0!
lx came with a d16y7 in 96-00 I believe.
The ex is better, but both are slow/gutless.
ex has shorter gear ratios, y7 has a differen't head and intake manifold, both of which flow better. the y8 is a higher compression and has vtec.
y8 130 bhp
y7 ~105 bhp
Old May 21, 2007 | 05:06 PM
97Ej6mike's Avatar
The y7 manifold is also a bitch and a half to work with, trust me, i used to have one, it was awful.
Old May 21, 2007 | 05:16 PM
Ek Forever y0!
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">The y7 manifold is also a bitch and a half to work with, trust me, i used to have one, it was awful.</TD></TR></TABLE>
A $50 auto y8 manifold is a nice little upgrade.
I did it, noticeable difference.
marcj
Jul 3, 2009 09:37 PM
thesilk
Jul 17, 2007 09:42 AM
iwanttogofast
Feb 16, 2007 03:25 PM
vvloolvv
Aug 24, 2006 03:07 PM
riplee
Nov 15, 2004 02:59 PM
