Sway bar tearing out of frame. :(
Old May 20, 2007 | 06:21 AM
LudemanDan's Avatar
Default Sway bar tearing out of frame. :(
My rear left sway bar chassis mount (I'm running a Suspension Techniques bar in back) has a habit of coming loose and clattering while I'm driving down the road. I've been tightening it down weekly, say, for the past month.
Looks like it can't be tightened any more:
That's the bolt hole pulling through.
Have a steel plate welded over it and rethread it? I'm a little nervous about welding that close to the gas tank. I need ideas so I don't have to go swaybar-less.
Dan
Old May 20, 2007 | 08:09 AM
typeS's Avatar
Default Re: Sway bar tearing out of frame. :( (LudemanDan)
Did you ever try thread-lock?
Old May 20, 2007 | 09:05 AM
shutta's Avatar
what is thread lock going to do to help that? it's ripping the subframe apart.
Search and you'll find that someone showed a repair for this.
Old May 20, 2007 | 10:30 AM
93sivtec's Avatar
Worst case scenario,just drop the gas tank,and then weld a new piece of steel in there.I dont see any other options for u.
Old May 20, 2007 | 12:29 PM
LudemanDan's Avatar
I took off both sway bars (stock front and ST rear) and I'm going to drive around today and see how bad the body roll is without them. I have Ground Control/Koni suspension so that should help somewhat.
Old May 20, 2007 | 04:31 PM
LudemanDan's Avatar
Well, I drove around today without sway bars and here is what I found.
It's actually not too bad - basically, it feels just like stock. But that's with Koni/Ground Control coilovers. So my suspension is doing the work my sway bars were doing before. Over straight-line one-wheel bumps, it's noticeably more comfortable. This makes sense, because since the springs are not tied together by the sway bar, the bumps are only pushing against one spring. Before, they were pushing against two.
The old familiar body roll is kind of annoying, so I might dial up the damping in my shocks (they're on full soft for the f*!%cked up streets of Oakland, CA), but otherwise, I can drive around with no sway bars without a problem. The ripped subframe can officially be a back-burner project.
BTW, more pictures:
The ripped out part of the subframe.
The white stuff is grease I put on there a little while ago when it started squeaking and creaking.
For reference, here's the other side, which is perfectly good.
As you can see, the bolt holes are spaced out farther, which probably prevented the right side from going bad.
Old May 20, 2007 | 05:00 PM
93sivtec's Avatar
Man u can have a shop weld that for cheap when your ready to get it fixed.Its a quick fix if u have a steel plate and a welder,and a drill press.
Old May 20, 2007 | 08:10 PM
LudemanDan's Avatar
I'm afraid I'd have to drop the gas tank before they strike the torch. The gas feeder tube is only a few inches away from the mounting bracket.
Old May 20, 2007 | 08:24 PM
AdReNaLiN's Avatar
Default Re: (LudemanDan)
I had a swaybar mount tear out of both front and rear. I ended up getting all of the swaybar subframe mounts welded up with 3mm thick steel plates - she aint gonna tear out anymore! (Y)
Its an easy job and you dont need to pull the gas tank.
Old May 20, 2007 | 10:55 PM
SnlpeR's Avatar
mine was a little worse than yours
then i had it welded with another plate on the side for more support
i originally wanted to box the chassis where it mounts too
but the welder was only able to access on side of the chassis
if it tears out....they will repair it for free
Old May 21, 2007 | 07:02 AM
LudemanDan's Avatar
That's pretty sweet. And your gas feeder hose is right there. I guess you can weld right there without being afraid of the car going boom. Cool.
Old May 21, 2007 | 03:37 PM
SnlpeR's Avatar
the gas hose can be removed pretty easily
just 2 clamps and a bracket or something
throw a flame retardant rag over it too
Old May 21, 2007 | 05:10 PM
johnny five's Avatar
mine looked exactly like snlper except both holes were rusted what my friend did was cut around the holes in a rectangular shape and cut the same shape from a bumper support beam, welded that to the frame. He then drilled holes for the bolts and he amazed me by putting nuts in the frame and welded them in then sanded it down sprayed some undercoating and bolted the sway bar back up "looks like factory" is what he said. this was back in november and still holding up
Old May 21, 2007 | 07:59 PM
RAB's Avatar
RAB
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">
This is the Progess set up. I've had mine welded like this for about 3 years. No problems.
Old May 21, 2007 | 08:04 PM
E-Money's Avatar
Default Re: (RAB)
I'm surprised ST did not supply you with beefier sway bar mounting brackets. The progress setup gives you everything.
Old May 22, 2007 | 12:29 PM
QUIETP_11's Avatar
exactly why I went with the Progress setup
Old May 22, 2007 | 12:52 PM
LudemanDan's Avatar
Ah, I didn't realize that. :/
reevear
Jul 28, 2011 04:25 PM
JunY
34
Feb 9, 2006 04:43 PM
ek4d00r
Suspension & Brakes
Apr 23, 2005 07:33 PM
katb16vo
22
Mar 25, 2004 03:29 PM
bluesaint
Jun 18, 2002 06:31 AM
