removing pin striping
Old May 20, 2007 | 01:18 AM
zanderclause's Avatar
Default removing pin striping
anyone know how to remove the pin striping on old accords really easily?
i heard it can be done with a heat gun
Old May 20, 2007 | 02:17 AM
YeuEmMaiMai's Avatar
Default Re: removing pin striping (zanderclause)
it depends if it is factory applied or not. if it is under the clear coat, you are sol, if it is above you can use a razor blade to remove it by slipping it between the pin stripe and the paint and gently pulling it up while applying heat from a hair dryer.
Old May 20, 2007 | 06:39 AM
stinker504's Avatar
If it's an old car be careful you may have some fading due to the sun and it'll look odd.
Old May 20, 2007 | 07:04 AM
j_man_honda's Avatar
Default Re: (stinker504)
I work at a car lot and we use an eraser wheel to remove pinstripes. It is 5x faster than doing it with a razor blade. Here is a link to a site: http://eastwood.resultspage.com/auto/eraser
Old May 20, 2007 | 07:57 AM
sweet thanks alot
90civicstdgold
Apr 12, 2010 01:39 PM
VTEC_PRODUCTION
Paint and Body
Aug 10, 2007 09:50 PM
HOUSTONb
Paint and Body
May 1, 2007 11:12 PM
ekdriven
Mar 8, 2005 08:00 AM
iam7head
Sep 25, 2002 07:05 AM
