Brake Pad Installation
Old May 19, 2007 | 08:13 PM
Midori Green's Avatar
Default Brake Pad Installation
im installing new pads on my 96 hatch... i was wondering what i have to do with the piston like how do i not introduce air into the system??
Old May 19, 2007 | 08:19 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Brake Pad Installation (Midori Green)
To get the pistion back down (which is what I think you're asking) Just use a c-clamp or some muscle with some vice grips and press it back down. Fluid will go back into the cylinder and reservior.
Old May 19, 2007 | 08:21 PM
viahiptop's Avatar
as long as you don't open the bleeder valve on the caliper, you will not allow ANY air into the system. Just swap, push the piston back, put the caliper back on and call it a day
Old May 19, 2007 | 08:24 PM
amej8's Avatar
I used a c-clamp and a metal file.
Old May 19, 2007 | 08:25 PM
Default Re: Brake Pad Installation (viahiptop)
thank you very much because i just started working at a shop in my neighborhood and i have no experience besides my backyard work and i do everything the ghetto way lol thats not good for customers cars
Old May 19, 2007 | 09:31 PM
Blk00EJ8's Avatar
Hmm, note to self. Don't go to any shops in Clifton, NJ...
Old May 19, 2007 | 09:37 PM
iceman7329's Avatar
Default Re: Brake Pad Installation (Blk00EJ8)
For real...
Old May 19, 2007 | 09:42 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">thank you very much because i just started working at a shop in my neighborhood and i have no experience besides my backyard work and i do everything the ghetto way lol thats not good for customers cars</TD></TR></TABLE>
Thank you for confessing that you do hack work on other people's cars.
Why didn't you just go work as a lube tech first so the only fucked up thing you could do was forget to tighten a drain bolt?
Old May 19, 2007 | 09:57 PM
Blk00EJ8's Avatar
Default Re: Brake Pad Installation (Eran)
You forgot that, on the other end of the spectrum, a drain bolt can also be over tightened.
Old May 20, 2007 | 02:17 AM
ahhsimon's Avatar
why must u use all that tools when all u need is 2 flat head and press on it against each other between the calibers to move the piston in a lil, ghetto but it workss
Old May 20, 2007 | 05:59 AM
Ramma's Avatar
take a c-clamp and the old pad and just depress the piston until its all the way in. And you should have someone like a professional helping you because messing with other peoples' cars isn't smart to do if you don't know too much. And no offense, but if you can't depress a caliper piston, you don't know much at all.
Old May 20, 2007 | 06:39 AM
Blue Papaya's Avatar
dont forget that in the case of the rear callipers they are adjustable, if the pad is to thin when you put a new one you will need to turn the piston so that it runs back making the room needed for the nw ones and the disc.
Old May 20, 2007 | 06:43 AM
kdatta33's Avatar
Default Re: Brake Pad Installation (ek forever guy)
Hey,
I did the same job last week myself.
Get Brakepade(mine Raybestos ceramic 36$ from Autozone), Brake cleaner and some good grease.
Its pretty simple. Get one chilton's manual also. I got that from local library.
To pushback the piston I used just a sturdy screwdriver.
Remember the brakefluid reservoir will overflow. So keep some waste cloth around it so the paint is not soaked.
Do it and you will save 70$ atleast.
SupremeDalek209
Suspension & Brakes
Jan 8, 2016 01:33 PM
dkaye4
Jun 27, 2007 04:58 PM
dgdarien
13
Feb 14, 2005 12:58 PM
david90
Jul 7, 2004 10:47 PM
sivik2nr
May 2, 2003 12:36 PM
