Possible damage from over-revving?
Old May 19, 2007 | 07:45 PM
stock99si's Avatar
Default i think i **** my pants a lil
okay so, today i was beatin on my em1, and as i was merging on the highway, goin about 60, i shifted into third and took it all the way to about 85ish. Then the fun part came in, i dont know why, but i always have a hard time shifting to fourth when im goin like 80ish, so as i was tugging on it, i think i went into second. i let go of the clutch for about 1 second, and the rpms ran down to about 10 k ;-), and then i pressed the clutch asap.. The car runs fine, i didnt notice any difference or anything like that, but im just wondering, has this happend to anyone, and what have i possibly damaged?
yea yea call me an idiot who doesnt know how to drive blah blah blah, but it didnt wanna get its *** in fourth :-/
Old May 19, 2007 | 07:53 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: i think i **** my pants a lil (stock99si)
Do a compression test. You may or may not have bent/floated a valve.
Old May 19, 2007 | 08:05 PM
stock99si's Avatar
Default Re: i think i **** my pants a lil (ek forever guy)
is there any way of finding out without compression test, and how exactly is a compression test done?
and lets say i bent or floated a valve, whats repair$?
Old May 19, 2007 | 08:30 PM
stock99si's Avatar
Old May 19, 2007 | 08:53 PM
94c1v1cex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">
and lets say i bent or floated a valve, whats repair$?</TD></TR></TABLE>
lets not talk about that... haha just get a compression test done
Old May 19, 2007 | 08:54 PM
99 Civic EX's Avatar
you need a compression checker, basically take out your spark plugs, put the tester in, crank the car a few times and you'll get a reading. if any of the readings seem really low compared to the other cylinders, then most likely you did some damage. From there, you'd have to pull the head off to replace the valves. does the engine still sound normal or is there anything that sounds abnormal while driving now? as for price, i'm not totally sure. depends on if you pay to have the work done or if you do the work yourself.
Old May 19, 2007 | 08:58 PM
stock99si's Avatar
Default Re: i think i **** my pants a lil (99 Civic EX)
no everythign sonuds normal, car runs normal aswell, i kept driving it couple of hours through the rest of the night, everything seems fine.
Old May 19, 2007 | 09:15 PM
amej8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">no everythign sonuds normal, car runs normal aswell, i kept driving it couple of hours through the rest of the night, everything seems fine.</TD></TR></TABLE>
bad idea. Even if you think the car was fine you should've checked it out.
Do a compression test as others have said. And how the hell do you mis-shift 4th and go into 2nd? Maybe going into 3rd from 4th instead of 5th is understandable (if you're not paying attention, which has happened to me once)...
20ls01's Avatar
how do you guys miss shift from 3rd into 2nd? seeems impossible if you ask me, but sooooooo many people have done it. Its just straight down and you have to angle it pretty good if you want it to go into second. 3rd to 4th is the easiest gear transition
Old May 19, 2007 | 09:26 PM
stock99si's Avatar
Default Re: i think i **** my pants a lil (amej8)
i dont know man i dont get how i did that, it seemed like i got it in fourth, i donno man, but if somethings fucked up im fucked. how much is usual price to do compression test?
Old May 19, 2007 | 09:28 PM
stock99si's Avatar
and how bout if i can dyno it, and get same power, does that mean everythings fine?
DaveSi677's Avatar
Everything looks to be ok!
Old May 19, 2007 | 10:31 PM
SoullessJapaneseMachine's Avatar
Default Re: i think i **** my pants a lil (DaveSi677)
i did the exact same thing im my gsr when i was racing, but i was at the top of 4th and put it in 3rd instead of 5th. i caught it but it went to at least 9k. it was scary but i dont think it damaged anything
Old May 19, 2007 | 10:52 PM
muhaMan's Avatar
whoo i havent misshifted yet.. i used to go from 1st, 2nd to 5th when i first got my car.. i was like "man 3rd gear sucks ***!!" then i realized i was going straight from 2nd to 5th lol
Old May 19, 2007 | 11:07 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test. You may or may not have bent/floated a valve.</TD></TR></TABLE>
do you know what it means to float a valve? its basically the same thing as fluttering a vave
to kids who dont know what they are talking about giving tech advice
Old May 20, 2007 | 05:47 AM
Ek Forever y0!
Default Re: i think i **** my pants a lil (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">do you know what it means to float a valve? its basically the same thing as fluttering a vave
to kids who dont know what they are talking about giving tech advice </TD></TR></TABLE>
You're a ******* troll. Get your lame **** off my website. I heard about your little fiasco last night.
Going to a dyno might be a good way to tell, but it sure as hell will be more expensive than getting a compression test done and might not show a power loss even if you bent a valve.
The only sure-fire way to see if damage was done is a leakdown test, compression test, or physically looking to see if a valve seal is loose or a valve itself bent or is was out of lash spec.
Team rs2, WTF are you talking about, most over-reving problems result in throwing rods, bent valves, etc.
Old May 20, 2007 | 05:52 AM
Ramma's Avatar
I know im jinxing myself typing this, but since i got a gsr turbo waiting to go in my car, i pretty much beat the **** out the motor. I rev my single to rev limit, 7200, and slam gears. Its stock. And i downshift a different way so that adds excessive wear as well. To tell you the truth, the car still runs amazing. Your car is probably fine, just try not to do it alot.
Old May 20, 2007 | 06:47 AM
JDMFantasy2k's Avatar
Default Re: (Ramma)
it's probably fine, my cousin mis shifted my turbo single cam an it hit 9100. After that i dyno'd it and the little **** threw down 206
civic-one
Apr 6, 2011 08:02 AM
JFG Kevin
Jul 19, 2006 07:49 PM
boosted_lude
Jan 27, 2006 09:31 AM
johnzm
Jul 26, 2004 07:46 AM
EF8_SiR
Jul 20, 2003 10:24 PM
