Just replaced axle on 97 Civic, now fluid leaking?
Old May 19, 2007 | 10:49 AM
SRd240sx's Avatar
Default Just replaced axle on 97 Civic, now fluid leaking?
I looked at the FAQ on this forum for the axle replacement and did exactly as it stated. I have to say it was one of the smoothest jobs I've done since I was pretty prepared. We didn't run into any problems at all.
One thing I did not do was grease the axle where it touches the transmission though. This sounds like all it does is lubricates it and reduces friction right? Well now after about 5 weeks later, I see fluid leaking out from where the axle meets the transmission. The install was about as smooth as it could get. Anyone have any idea what it could be?
Old May 19, 2007 | 10:55 AM
deepbluerocket's Avatar
Default Re: Just replaced axle on 97 Civic, now fluid leaking? (SRd240sx)
you grease the axle to keep from damaging the seal and that is most likely what you did. its not likely but the new axle may be a little smaller than the old one.
Old May 19, 2007 | 11:08 AM
Cookie's Avatar
Default Re: Just replaced axle on 97 Civic, now fluid leaking? (deepbluerocket)
Possible o-ring slippage?
Old May 19, 2007 | 12:50 PM
SRd240sx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepbluerocket &raquo;</TD></TR><TR><TD CLASS="quote">you grease the axle to keep from damaging the seal and that is most likely what you did. its not likely but the new axle may be a little smaller than the old one.</TD></TR></TABLE>
What does it take to replace the seal? What's the actual name of this seal?
Old May 19, 2007 | 02:23 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It's called an axle seal. You need to pull the axle again, and replace it.
A seal puller tool gets it out in seconds. But, you can different things to pull it out.
slagman
Mar 16, 2017 03:29 AM
TEGMAN89
Jan 11, 2011 05:12 AM
ahloung
15
Mar 14, 2006 11:52 AM
Mario.
Dec 16, 2004 02:25 PM
See Are X
Oct 21, 2003 09:23 PM
