Clutch Fluid Leaks
Old May 19, 2007 | 10:44 AM
StevenIrek's Avatar
Default Clutch Fluid Leaks
Howdy!
I have a 98 Honda Prelude w/ ~120k miles on it. I have recently been having a problem with the clutch fluid leaking at a fairly decent rate. I have to refill it about once a month for the past 2 months. I have checked the line and cannot find any areas where the fluid is leaking. I was hoping that someone else has had a similar problem and can help me out.
Thanks
Steven
Old May 19, 2007 | 12:14 PM
Hawkze_2.3's Avatar
Default Re: Clutch Fluid Leaks (StevenIrek)
Well, there's not much to the clutch hydraulics. Check the fitting on the master cylinder, check the hard line, and check the fitting and seals on the salve cylinder. There is a boot on the slave that you may need to pull back to check the seal.
It has to be leaking from somewhere....try physically touching everything to make sure it's not wet.
Old May 19, 2007 | 12:30 PM
E-Money's Avatar
i have/had the same problem
Old May 19, 2007 | 02:18 PM
Eddiebx's Avatar
theres also the clutch dampener that i've heard is notorious for leaking, this is located on the passenger side below the shock tower i believe, i am not sure exactly where it is on a prelude, because i own an accord.
Old May 19, 2007 | 02:38 PM
Hawkze_2.3's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">theres also the clutch dampener that i've heard is notorious for leaking, this is located on the passenger side below the shock tower i believe, i am not sure exactly where it is on a prelude, because i own an accord.</TD></TR></TABLE>
I forgot about the damper! (mines been gone for a while )
Here's the whole line and damper, which should be on the passenger side frame rail...
Old May 19, 2007 | 05:47 PM
ninja 6's Avatar
Default Re: (Hawkze_2.3)
There is way too much **** in a clutch system...why can't they just put a straight shot SS line from the reservoir to the slave cyl...
Old May 19, 2007 | 07:19 PM
prelude1897's Avatar
Default Re: (Ninja 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja 6 &raquo;</TD></TR><TR><TD CLASS="quote">There is way too much **** in a clutch system...why can't they just put a straight shot SS line from the reservoir to the slave cyl...</TD></TR></TABLE>
only cause Honda loves to make everything difficult just like getting to the fuel filter on the 97-01 Preludes
Old May 19, 2007 | 07:24 PM
E-Money's Avatar
which part is the damper?
Old May 19, 2007 | 07:41 PM
SteveoBA8's Avatar
Default Re: (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">which part is the damper?</TD></TR></TABLE>
Where # 10 and 11 thread into.
Old May 20, 2007 | 03:46 AM
IIVIIoOkY's Avatar
Default Re: (SteveoBA8)
just from this happening to me currently i would probably have to say its your master cylinder. mine has a crack in it and has the same symptoms as what your getting now. get that checked out. its nothign crucial but its just kinda a PITA when you have to keep re filling it.
Old May 20, 2007 | 08:31 AM
Jason-K's Avatar
Default Re: (IIVIIoOkY)
check and make sure bolt number 13 is tight and has crush washers. thats where my leak was. also, how far do you have to push your clutch pedal down before it engages/disengages?
mr.mengo
Dec 28, 2013 01:51 PM
importknight
Dec 27, 2010 08:46 PM
atmusicman85
Apr 18, 2008 06:21 PM
jajackson
Nov 16, 2007 08:50 AM
951dc5
Oct 1, 2004 10:44 PM
