clutch slipping?? lsd broke?? need diagnosis help....
Old May 19, 2007 | 09:36 AM
gogunkergorilla's Avatar
Default clutch slipping?? lsd broke?? need diagnosis help....
So first i should mention that i drove the car for about 50 miles with no oil in the transmission because I thought there was oil in it but I didn't check. oops!! there was damage to the synchros, but i replaced them and now it shifts smooth.
anyway, whenever I step on the brakes when the car is moving or step on the gas while the car is stopped i hear a click sound coming from the driver side (i think). no clicking around when turning.
also, my clutch was slipping but I don't think i was overpowering it. i only have a euro r/h23 with a t3/t04e at about 20-23psi. the clutch should hold 350lbs/ft and i don't think my setup is capable of that.
it would pop and spin kind of like stepping on the pedal and blow out a cloud of dust. i replaced the clutch, (an act hd 6 puck and stock flywheel) with an act xtr 6 puck and streetlite flywheel and the release bearing. it held fine for a week, the clicking sound went away too at first but it gradually came back after a few starts and stops. i drove it this morning and somthing (the clutch??) popped loose when i tried to wind out 4th gear.
any ideas as to what could be loose or broke???
TegProject
Aug 31, 2007 03:23 PM
NOSED_CRX_VTEC
Oct 7, 2004 11:20 AM
TurboBumblBee
Jul 19, 2004 05:42 PM
Nick248
May 23, 2003 10:00 PM
turbo Si
May 5, 2002 08:44 PM
