Distributor?
Old May 19, 2007 | 07:30 AM
TAINO's Avatar
Default Distributor?
I have 1994 honda accord lx. The distributor is leaking from the inside. I changed the O-Ring but is still leaking. I have been told that i have to replace the distributor. Is that true. Can someone help me here.
Thank
Old May 26, 2007 | 06:17 PM
TAINO's Avatar
Default Re: Distributor? (TAINO)
Thank you guys. For the help and replies.
Old May 27, 2007 | 08:34 AM
gherrera06's Avatar
You must change distributor seal, it's inside distributor!...easy to change it....www.partstrain.com... in my case (honda accord 1997),item name "Distributor Seal" Part #F2100-65416
saludos
from Panama
Old May 27, 2007 | 11:02 AM
chibiko's Avatar
when you take off your distributor, don't forget to make marker of its position relative to the engine. The position of it determines the fire timing.
lufth
Nov 14, 2013 12:38 AM
blacktibby07
11
Feb 5, 2011 03:12 PM
WVhump
Acura TL, RL & ZDX
Mar 28, 2007 10:30 PM
