Brake Question
Ok i got a 93 Civic EX coupe
i was told it had GSR hubs...but im not entirely sure, but i was also told that GSR rotors and calipers were a direct bolt on
i also recently converted to rear discs using integra rear discs, problem with this is that im not sure if they are GSR or ls...is there a difference?
Im asking these because i want to do a brake upgrade....i know i need SS lines for a 92-95 civic SI
but im not sure what kind of rotors and pads i am able to bolt up to my setup
anyone know? thanks ahead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">i also recently converted to rear discs using integra rear discs, problem with this is that im not sure if they are GSR or ls...is there a difference?
Rear will not matter, GSR or LS/GS.
Im asking these because i want to do a brake upgrade....i know i need SS lines for a 92-95 civic SIanyone know? thanks ahead</TD></TR></TABLE>
In your case, we'd order them for a 95 GSR. Really, the kits are only different for the difference of rear drums or rear disk set ups. However, we just order the Integra ones so that a parts guy doesn't screw up and order Civic's w/o rear disk -since the 95 Integra all had rear disk -less likely to get a messed up order.
allanonjj
10
Dec 2, 2005 03:38 PM
703_Sleeper
May 23, 2004 05:49 PM
