wilwood brake line and bleeding question? please help
Old May 18, 2007 | 05:22 PM
ramz7887's Avatar
Default wilwood brake line and bleeding question? please help
When you bleed the 4 piston caliper do you start with the top 2 one at a time and then bleed the bottom two? Also do you just loosen the bottom part of the bleeder screw ( where its gold) or on the black part on top. Also should you start the car while bleeding?
Also on the new SS lines with the plastic coating they have a built in 90 degree bend at one end. Does it matter which side that bend connects on?
I also spilled a little brake fluid on top of the alternator. Would that cause the car not to start? I'm gonna let it sit and see if it will start.
ciro
Suspension & Brakes
Oct 23, 2010 07:49 AM
italian_virus
Jul 29, 2010 06:12 PM
ramz7887
May 19, 2007 08:43 AM
ramz7887
May 19, 2007 08:08 AM
The Dirty EJ1
15
Aug 25, 2006 08:29 PM
