91 civic won't start when hot
Old May 18, 2007 | 05:03 PM
7panget's Avatar
Default 91 civic won't start when hot
i got a 91 civic si and i have a problem with it, sometimes when its HOT it won't start. new spark plugs and wires, good battery. then i wait for 10-20 min to start again. then after it started and drove, it didn't happen again.
Old May 18, 2007 | 06:56 PM
ED6JDM's Avatar
Default Re: 91 civic won't start when hot (7panget)
Get your ECU tested!
Old May 18, 2007 | 08:17 PM
DEIVIONCRX's Avatar
Classic Main Relay
Old May 18, 2007 | 09:42 PM
PiMpIn's Avatar
Default Re: 91 civic won't start when hot (DEIVIONCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">Classic Main Relay</TD></TR></TABLE>
Old May 18, 2007 | 10:26 PM
dj-t's Avatar
I have the same problem with my 90 hatch. It would turn like it just about to catch on but nope. When it does it sounds like I guess it's running out of gas. I thought it was the main relay but after reading what is on this site (http://techauto.tripod.com/mainrelay.htm) and going through it and checking how it says on the site, doesn't seems like it is the main relay. Maybe just have to replace it and find out.
Old May 18, 2007 | 10:38 PM
Colonel Warden's Avatar
It definitely has to be the main relay. They happen to get small cracks in the chip-board. Good luck getting it fixed... I always carry a spare with me.
Old May 18, 2007 | 10:39 PM
DEIVIONCRX's Avatar
Default Re: 91 civic won't start when hot (dj-t)
Just pull the main relay, resolder the couple points all the Write-up's point out, and try it. Doesnt cost anything and is usualy the problem.
Old May 18, 2007 | 10:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">Just pull the main relay, resolder the couple points all the Write-up's point out, and try it. Doesnt cost anything and is usualy the problem.</TD></TR></TABLE>
Oh man, that isn't for the "electronically inept". That's hard work!
Old May 18, 2007 | 11:04 PM
dj-t's Avatar
Default Re: (Citizen1)
In my case if it was the main relay and I get the car to start, the motor should not be bogging and hesitating. Or can the relay contribute to it?
Old May 19, 2007 | 02:29 AM
DOHCturbo02's Avatar
Change out your main relay, i got mine from scott robinson honda in torrance (SoKal) for $63. 20 min install for a noob!
Old May 19, 2007 | 09:46 PM
7panget's Avatar
i chage my main relay already, i hope it works..... thanks for all help
Juan_Mitosis
May 28, 2009 07:23 AM
95_red_dc
Nov 1, 2007 04:18 PM
95excoupe
17
Jun 17, 2007 03:47 AM
kittieeve
Jun 1, 2006 02:31 PM
triple_s1x
Feb 27, 2005 11:10 AM
