tranny sqeaking what is wrong?
Old May 18, 2007 | 04:18 PM
lunatics209's Avatar
Default tranny sqeaking what is wrong?
i got a gs-r lsd tranny i installed about 4 months ago. right now in first gear i let go of the clutch it sqeaks, with it in gear. have any of you guys experienced this or know what is wrong? i checked my clutch master cylinder and slave cylinder and its still shooting out fluid. also when i put the tranny in i had a brand new act 4 puck disc but a used act pressure plate.
Old May 18, 2007 | 04:50 PM
hitekper4mance's Avatar
Default Re: tranny sqeaking what is wrong? (lunatics209)
Let me know if you get an answer. HAHA. I am sure someone knows the answer but... welcome to the world of not stock. One of my cars does the same thing. It has a quaife diff, jun flywheel, and a steel clutch. My other car has the same but 4puck instead of the steel clutch. Havent driven it enough to know if it squeeks too. But, I' be interested in the answer to this too!!
Old May 19, 2007 | 11:13 PM
up..plz help..
Old May 23, 2007 | 03:12 PM
I just dropped a factory GSR tranny in the car and it still squeaks a little. I think my clutch is going out though. I am gonna have it checked out tomorrow. If they replace anything and the squeaking goes away, I'll let you know. I dont think it has to do with the tranny or the differential though.
Old May 23, 2007 | 03:25 PM
9200RPM's Avatar
does it only squeek in 1st gear...and not when you push and release the pedal?
Old May 25, 2007 | 10:24 AM
Default Re: tranny sqeaking what is wrong? (TurboB16aEG)
its squeaks when the clutch clamps. im thinkin the pressure plate being worn out.
Old May 25, 2007 | 11:10 PM
Legion's Avatar
* B A N N E D *
Welcome to the world of cerametallic clutches. They often sqeal like a dying animal when they engage, especially if you have some nice burn marks on your flywheel or friction ring.
Your original post was kind of confusing, but my guess is that it's normal clutch squeal. My competition clutch 6-puck squealed so bad I finally ditched it in favor of a Clutch Specialties which doesn't have any squealing issues. Also, a resurfaced flywheel is a must if it's heavily glazed/burned. Did the pressure plate have a bunch of burn marks on it?
Old May 26, 2007 | 12:38 AM
Default Re: tranny sqeaking what is wrong? (Semtec)
i have not taken my tranny apart but it seems that some people i asked have told me that this is usual. yea should have went with new flywheel and pressure plate but that was what came in hand at the time. thanks for all the info.
Trix-88si
Sep 29, 2008 10:56 AM
dopefeen
Jul 15, 2006 09:04 AM
omega2099
Aug 25, 2004 11:41 AM
Mark
Jun 14, 2003 04:51 PM
HX_Guy
Aug 29, 2001 09:09 AM
