what is wrong with my car????
Old Jun 1, 2002 | 04:50 PM
dubletke's Avatar
Default what is wrong with my car????
im sure everyone is getting tired of me postin this but im so sick and tired of this thing not running. as far as i can tell i have tryed just about everything i know to get this thing to idle smoothly. ill see what i can remember eacv, adjusted tps, ta sensor the one on the im, both o2 sensors, coolant temp sensor, pcv, changed the vacuum hoses around, changed the brake booster thinking it had a leak, but yet to no avail the thing still will not hold a steady idle, also bled the coolant many times. now this is where it gets odd it idles fine for a few seconds then if u turn on the lights or hit the brakes then the car will never idle again just up and down. i have yet to be able to figure out why it is always consistant with the a/f gauge. if i put the primary o2 on c16 and secondary on c8 idles fine but runs like crap change it the other way runs great idles crappy. disconnect the sec o2 and the ecu throws a code for the tps hook it back up the code goes away. also if i adjust the tps to .35v it idles fine but does crappy on the street no throttle response. but at .45v or .5v it has throttle response but wont idle. but if any one has any suggestions im at a loss. oh yea also tryed a new map sensor. thanks bradley
chris d
Sep 10, 2015 03:35 PM
kpop
Feb 18, 2008 04:40 PM
mr. carpenter
Feb 8, 2004 12:03 PM
Aeka GSR
Dec 16, 2003 01:58 PM
