will a stock ek hatch exhaust (d series) fit on stock b16 header?
Old May 18, 2007 | 01:06 PM
aboos's Avatar
Default will a stock ek hatch exhaust (d series) fit on stock b16 header?
basically what i what to know is..
will a exhaust system coming off an EK hatch with a b16, stock header (those 2 piece heavy *** ones) fit on a bone stock EK hatch with a d-series motor with a stock header? thanks.
Old May 18, 2007 | 01:16 PM
kaiba's Avatar
Default Re: will a stock ek hatch exhaust (d series) fit on stock b16 header? (aboos)
Stock headers??? NO
Old May 18, 2007 | 01:22 PM
Eran's Avatar
HT White Ops
It'll be too long. I had to cut out a section of my exhaust and reweld the flange to bolt up to the cat using an LS exhaust manifold (same length as B16).
You may be able to use a GSR Exhaust Manifold and catalytic converter. Those are quite a bit shorter.
Old May 18, 2007 | 01:24 PM
aboos's Avatar
Default Re: will a stock ek hatch exhaust (kaiba)
im assuming no also, but how about to the cat? will it fit up to the stock b16 cat? it doesnt even have to fit perfectly, its more for show than anything.
Old May 18, 2007 | 01:25 PM
Eran's Avatar
HT White Ops
As long as it's the two-bolt flange that's kind of diamond shaped.
If it's the 3-bolt triangle flange, you'll need to go to a muffler shop and get a new flange welded on.
aboos's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">It'll be too long. I had to cut out a section of my exhaust and reweld the flange to bolt up to the cat using an LS exhaust manifold (same length as B16).
You may be able to use a GSR Exhaust Manifold and catalytic converter. Those are quite a bit shorter.</TD></TR></TABLE>
do you remember about how much longer?
Old May 18, 2007 | 01:26 PM
Eran's Avatar
HT White Ops
Default Re: (aboos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aboos &raquo;</TD></TR><TR><TD CLASS="quote">
do you remember about how much longer? </TD></TR></TABLE>
3-4 inches.
Old May 18, 2007 | 01:27 PM
aboos's Avatar
Default Re: (Eran)
alright, thanks man. appreciate it.
Old May 18, 2007 | 01:29 PM
Eran's Avatar
HT White Ops
Bah, reverse what i said.
If you have the two-bolt flange, you'll need the 3-bolt.
The end of the cat that attaches to the header has the two-bolt diamond flange, the part that bolts to the exhaust is the 3-bolt triangle flange.
Old May 18, 2007 | 01:34 PM
aboos's Avatar
Default Re: (Eran)
hahaha alright...so the stock b16 cat, the end is a 3 bolt flange? and the d-series stock exhaust is a 2 bolt flange? did i get that right?
SL0-hatch
Feb 24, 2021 09:32 AM
milkwasabadidea
Nov 22, 2010 11:59 AM
forcefedish
Aug 26, 2005 07:11 AM
LSVTEC408
Dec 15, 2003 09:56 PM
Agent STFU
Aug 18, 2003 10:32 PM
