Need Opinions & Suggestions with my FI setup (CRX)
Old May 18, 2007 | 12:57 PM
sonzilla's Avatar
Default Need Opinions & Suggestions with my FI setup (CRX)
Ok any day now I'll have my car sent to the shop to finish the install.
Here is a list of the mods I have below so far.
I would like to know if anyone can agree to the choices I made in parts and what power should I be expecting? Reliability in the parts I chose? Suggestions etc. etc.
I've done swaps and work on Nissan's but this is my first built Honda so I had one of my friends advise me along with the build up. So I just want to hear from others on what they think so far on my mods.
<U>Engine Modifications</U>
LS Bottom
B16 Head
Bored Over .5
Three Angle Valve Job
Ballanced and Blueprinted Bottom End
Block Guard
Eagle H-Beam Connecting Rods
WISECO Pistons-K541M815
Crower Cams Stage 2 - 63401T-2
Crower TITANIUM Retainers, Dual Springs
Ferrra Valves
Skunk 2 Cam Gears
Skunk Intake Manifold
AEM High Volume Fuel Rail and FPR
Walbro 255lph
Turbonetics Stage III T3/T4 Hybrid 60trim
450cc Fuel Injectors
Denso Iridium spark plugs
Accel plug wires
<U>Electronics</U>
Safc II
OBD 0 ECU
MSD ignition box
HKS turbo timer
<U>Transmission</U>
ACT Four Puck Disk
Light weight Aluminum Flywheel
Stock 5spd
Non LSD
<U>Exhaust</U>
3" all the way back NO Cat
Thanks guys this is my first post take it easy on me
Modified by sonzilla at 2:14 PM 5/18/2007
Old May 18, 2007 | 01:05 PM
raene's Avatar
Default Re: Need Opinions & Suggestions with my FI setup (sonzilla)
You don't really need the cams, gears, intake manifold, rail, FPR, ignition box... I would put those into getting an LSD and upgrading your injectors, 450cc max out around 300 and that setup should be good for 4. What are you using for manifold/blowoff valve/etc?
Or you could put that money into a move to OBDI, it lets you rev a little higher more reliably.
Old May 18, 2007 | 01:17 PM
sonzilla's Avatar
Default Re: Need Opinions & Suggestions with my FI setup (raene)
Custom Manifold shop made, Turbonetics wastegate, HKS BOV, ARP Bolts
Can you explain a little more as to why I wouldn't need the above parts you mentioned?
Old May 18, 2007 | 01:32 PM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sonzilla &raquo;</TD></TR><TR><TD CLASS="quote">Custom Manifold shop made, Turbonetics wastegate, HKS BOV, ARP Bolts
Can you explain a little more as to why I wouldn't need the above parts you mentioned?</TD></TR></TABLE>
The oem ones are better and the IM wont make that much diff.
Old May 19, 2007 | 03:18 PM
sonzilla's Avatar
The OBD-0 computer I have the shop says it's good for a 9K rev. This is my second build the first build I fried my shims and caused some rod damage due to oil starvation. I registered 8600 rpm on the SAFC a couple times before.
So I guess other then what has already been mentioned this setup should be good for a reliable 270whp - 300whp?
Also say I do get bigger injectors to meet 400hp figures will the block handle that amount of power without sleeves?
Old May 19, 2007 | 10:12 PM
TheShodan's Avatar
Moderator
Default Re: (sonzilla)
With the larger injectors needed, you'll need better fuel managment than the SAFC. You may have tuned on that before, but the SAFC is very limited in its abilities to control these injectors reliably.
Old May 19, 2007 | 10:19 PM
LoseRPunKx182's Avatar
Default Re: (TheShodan)
with all the money invested i would ditch the safc. hondas arent as forgiving as other cars on a hack..get a management that can tune more map resolution
Old May 19, 2007 | 10:34 PM
PiMpIn's Avatar
Just as a personal opinion I would convert to obd1 and get yourself a nice management system. You may wanna think about a LSD if you wanna push 400 whp. LSD can make a world of difference.
Old May 20, 2007 | 07:17 AM
sonzilla's Avatar
Default Re: Need Opinions & Suggestions with my FI setup (PiMpIn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiMpIn &raquo;</TD></TR><TR><TD CLASS="quote">Just as a personal opinion I would convert to obd1 and get yourself a nice management system. You may wanna think about a LSD if you wanna push 400 whp. LSD can make a world of difference.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">with all the money invested i would ditch the safc. hondas arent as forgiving as other cars on a hack..get a management that can tune more map resolution</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">With the larger injectors needed, you'll need better fuel managment than the SAFC. You may have tuned on that before, but the SAFC is very limited in its abilities to control these injectors reliably.</TD></TR></TABLE>
First I like to say thanks to all the helpful input you guys have provided. I also read allot of threads in this forum and learned quite a bit, very helpful forum.
Now back on topic, ok so the LSD I know is a must aswell as tossing out the SAFC, convert to OBD1 along with a proper management system.
I think this would be my last question, I see allot of people on here using Hondata is this something I should consider getting?
Second you say 400hp the tuner who built my motor says I'm only good for 350hp max, without blowing the motor because I'm not sleeved.
But I hear it can handle around 400hp stock is this true???
I just have no experience with the LSV to determine what it can handle safely with the mods I have.
Old May 21, 2007 | 09:04 AM
PiMpIn's Avatar
it can depend alot on who tunes the car with turbo you have bevery careful with detonation if you have an incredible good tune it may be possible but on an ls bottom end i would probably sleeve it. i now a kid that has a 450 wheel integra da and they sleeved it when he wanted to make at the 400 whp range.
umair
Mar 29, 2009 07:43 PM
Steak84SS
Feb 7, 2006 06:40 PM
st00pid
Jul 23, 2003 04:44 PM
95si
Jan 25, 2003 08:27 PM
