door won't open from inside\outside
Old May 18, 2007 | 12:18 PM
USDM DC4's Avatar
Default door won't open from inside\outside
okay guys I need some help I don't usally post here but I have to help my friend out she drives a 96 4 door civic and the door doesn't open from the outside..it did from the inside till one of her friends put on the child lock on..and yeah so now it won't open..question 1..can I remove the rear passanger door panel with the door closed? if I can question 2...what should I lloook for?? thanksinadvance
Old May 18, 2007 | 06:47 PM
USDM DC4's Avatar
Default Re: door won't open from inside\outside (USDM DC4)
pleaase anyone??
Old May 18, 2007 | 07:40 PM
muhaMan's Avatar
dont know much about EK doors but you gotta have the door open to remove the door panel
Old May 18, 2007 | 07:55 PM
ke98248's Avatar
Default Re: (muhaMan)
He's right, there's no room to remove the door panel. First of all, there are 5 screws you have to take out, and numerous plastic snap-ins pieces.. ALso the tweeter must be popped loose from the top with a flat screwdriver to even get the door panel off. Sorry, so unless you want to destroy the panel to get to the door lock mechanism and get a new one at the junkyard/honda dealership (rip-off), you're outta luck..
Old May 18, 2007 | 08:52 PM
96GSRcx's Avatar
Default Re: (ke98248)
I think he's talking about a rear door as they should be the only ones with a child safety lock, right? most of what they said still applies though. Try taking the rear seat out and see if you can see all the edges of the door panel. If you can you might be able to take it off. You'll be looking for a rod that comes from the outside door handle. It will most likely still be in the handle and where the other end connects, it will have come off or broken the plastic tab that holds it in. Worst case scenario, she'll have to buy a new door panel and a new outside handle. Just be sure you have disconnected everything before you go ripping away.
Old May 19, 2007 | 05:45 PM
ke98248's Avatar
Default Re: (96GSRcx)
Yeah, I'm quite sure he'll have to destroy the panel to get to it.
Old May 19, 2007 | 06:19 PM
solsi's Avatar
tried a slim jim? Coat hanger?
raider1qaz
Feb 19, 2013 01:43 PM
YKPhil
Jan 7, 2013 02:23 PM
Rayzorx
May 30, 2011 06:46 PM
96teggynonVtec
Jan 7, 2007 05:07 PM
