camber kit question
Old May 18, 2007 | 10:44 AM
memo69's Avatar
Default help
what are the differnces between the rear and the front camber kits
Old May 18, 2007 | 10:46 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: help (memo69)
not to be rude but... have you looked at pictures of them? It's pretty obvious.
Old May 18, 2007 | 04:05 PM
memo69's Avatar
if i chance the front kit ill have to chace the rear one too or i have to both a the time
Old May 18, 2007 | 07:21 PM
accord380whp's Avatar
DUDE , do you even know the pupose of a camber kit , It is for aligning the wheels on the car to compenstate for a lowered suspension, If you lowered the car , and you never had it aligned. You will eat the inner tire to the belts. While the outside will be looking brand new. Now after you wasted the first set of tires you finally look into the camber kit. What this kit does it make the tires straight, so you can get more life out of your tires . So why would you justwant to replace , or as you say ?? chance ?? the front or the rear. Do both and get the car aligned. Its only for people who have dramatically lowered there car, like me I went 3 1/2 inches all the way , so I got a 350 camber kit with a 140 alignment. I dont recommend ebay junk for 50bux. And the difference is the front just replaces the balljoint in the uppercontrol arm and the rear replaces the whole upper control arm . But keep that search button handy !!
vtec99ej
Mar 3, 2007 08:40 AM
nhiczx
Jul 10, 2006 12:03 PM
gospeedgo1
Jan 23, 2006 09:54 AM
civicracer12381
Apr 25, 2004 05:35 PM
