Buddy club stg 5????
Old May 18, 2007 | 10:22 AM
Blackturbohatch's Avatar
Default Buddy club stg 5????
Here is set up
b20 84.5mm 14.1 cr
gsr head tsr port/polish
supertech valve spirngs/retainers
jg edelbrock im
70mm tb
buddy club stg 5 cams
do you think this cam is over kill? And how much power can be expected on a set up like this?
Old May 19, 2007 | 05:45 PM
Salsa's Avatar
Default Re: Buddy club stg 5???? (94lsvtecturbocivic)
no, defenitaly not overkill with 14:1 comp, go for it
Old May 20, 2007 | 01:43 AM
OUT OF ORDER ROB's Avatar
Default Re: Buddy club stg 5???? (Salsa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Salsa &raquo;</TD></TR><TR><TD CLASS="quote">no, defenitaly not overkill with 14:1 comp, go for it</TD></TR></TABLE>
i was thinking about getting these cams too, But i have 12:5:1 comp 84.5 will i be able to run pump gas?
Old May 20, 2007 | 04:11 AM
Dyno Dave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsvtecturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">Here is set up
b20 84.5mm 14.1 cr
jg edelbrock im
70mm tb
do you think this cam is over kill? And how much power can be expected on a set up like this?</TD></TR></TABLE>
Just use a very good header on that setup with those cams and you will be very happy with the results.
Regards Dyno Dave
Old May 21, 2007 | 08:34 AM
Default Re: Buddy club stg 5???? (Dyno Dave)
just got back from nopi. the car isnt running right it went a 12.7 @ 107. The tuner thinks it is a problem with the port work of the head? tsr did the head work and it looked ok. it doesnt break up it runs good but no power. i know the a/f were 13.9 during the pass and the egt got up to 1100. Does anyone have any ideas what could be wrong?
Old May 21, 2007 | 10:07 AM
ST4TUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Salsa &raquo;</TD></TR><TR><TD CLASS="quote">14:1 comp, go for it</TD></TR></TABLE>
You will be very satisfied with that comp.
Old May 21, 2007 | 02:32 PM
93-lsvtec-eh2's Avatar
Default Re: Buddy club stg 5???? (OUT OF ORDER ROB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER ROB &raquo;</TD></TR><TR><TD CLASS="quote">
i was thinking about getting these cams too, But i have 12:5:1 comp 84.5 will i be able to run pump gas?</TD></TR></TABLE>
you should be fine these cams bleed of alot of compression because they are so big so your static compression will most likely drop into the mid 11's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsvtecturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">just got back from nopi. the car isnt running right it went a 12.7 @ 107. The tuner thinks it is a problem with the port work of the head? tsr did the head work and it looked ok. it doesnt break up it runs good but no power. i know the a/f were 13.9 during the pass and the egt got up to 1100. Does anyone have any ideas what could be wrong?</TD></TR></TABLE>
is the car tuned on the dyno or just street tuned?
if your still interested in the cams i have a set for sale check my sig or send me a pm.
Old May 21, 2007 | 05:39 PM
Default Re: Buddy club stg 5???? (93-lsvtec-eh2)
i already have the cams installed when then took the car to the dyno( it was a mustang) it put 197hp and 138trq its not my car it is my friends car, like i said before the tuner seems to think that a bad port and polish is killing the power.
blkb18
Oct 9, 2006 04:02 PM
ekblacknight
Oct 25, 2005 05:46 PM
DEMNTD1
Sep 27, 2005 09:17 PM
goodfella732
Oct 6, 2004 03:28 AM
integlspwr2k
Dec 15, 2003 08:04 AM
