How to change the oil cooler o ring on an H23?
Old May 18, 2007 | 09:04 AM
dk4ever's Avatar
Default How to change the oil cooler o ring on an H23?
I have oil comin out of the back of the oil cooler right up against the block. Just wandering how do I get it off and what do I need to change? Any help will be greatly appreciated.
Old May 18, 2007 | 03:21 PM
m00nr0ck Si's Avatar
Default Re: How to change the oil cooler o ring on an H23? (dk4ever)
I just did this and its pretty simple, probably took about 30 minutes.
-take off oil filter
-use a deep 30 mm socket to remove the center bolt that holds the cooler on.
-remove old ,flat,crusty o-ring
-install new o-ring with a light cote of silicone sealant to prevent the o-ring from binding when tightening.
-torque center bolt to 40 ft./lbs.
-re-install oil filter
-enjoi no oil leaks!
Old May 30, 2007 | 07:57 AM
dk4ever's Avatar
Aight cool preciate it. Will due.
marcus81184
Feb 5, 2009 09:25 AM
jimmy193
Aug 17, 2008 02:29 AM
bboixtc
Jul 2, 2006 05:55 PM
mr abstract
Aug 9, 2005 05:15 AM
fubar
Aug 20, 2002 11:50 AM
