Are all d series shortblocks the same?
Are they all the same in aspect to installing a Sohc vtec head (mini-me)?
The reason I ask is because I was wondering if there is a difference between the sohc blocks and the dohc blocks (zc) like waterpumps, timing belts, head studs, ect. when doing a mini-me conversion between the 2 blocks.
This is what I want to do:
d16a (zc) stock shortblock + D16y8 head
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine »</TD></TR><TR><TD CLASS="quote">Are they all the same in aspect to installing a Sohc vtec head (mini-me)?
thanks</TD></TR></TABLE>
zc dohc block is slightly different, and will not allow bolt on for SOHC head without modifing the block and the head!
duefuss
Jan 24, 2008 09:12 PM
CivicRaping
Sep 25, 2005 10:50 PM
blocks should be the same. I would check teeth on water pump and timing belt.
