ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ??
Old May 18, 2007 | 12:13 AM
loverboy's Avatar
Default ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ??
Hello guys !
Can i put the ITR gauge cluster into my civic 96 coupe ??
Is there any modifications that ill need to do ??
I think it looks much better than the CTR cluster!
Thanks.
Old May 18, 2007 | 10:45 AM
eg6ajk's Avatar
Default Re: ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ?? (loverboy)
some how to for 96-00 civic guys:
http://www.merritr.com/gauge.html
or
https://honda-tech.com/zerothread?id=1053318
or
Pic is borrowed from one of the threads
Old May 20, 2007 | 12:42 PM
loverboy's Avatar
Default Re: ITR gauge cluster swap into civic 96 coupe (eg6ajk)
Thanks my friends realy great information !!
Is it matter which gauge cluster spec im using ? (94-97 or 98-01)
Does it depends on which enine swap ill do ? for example if ill do a 99 ITR swap is it matter if im using the 98-01 cluster or the 94-97 ?
What r the advantages of the newer cluster if there any ?
Thanks.
Old May 20, 2007 | 12:45 PM
RotiEatter's Avatar
Ditto
Default Re: ITR gauge cluster swap into civic 96 coupe (loverboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loverboy &raquo;</TD></TR><TR><TD CLASS="quote">What r the advantages of the newer cluster if there any ?
Higher tach and speedo.... but it never looks just right in a Civic.
Old May 20, 2007 | 01:34 PM
loverboy's Avatar
Default Re: ITR gauge cluster swap into civic 96 coupe (RotiEatter)
I didnt understand what u mean i have looked on them and they have the same tach and speedo??
Any way ill steel didnt get the answers the the other questions (the more important ones) ??
Old May 20, 2007 | 03:01 PM
EKlscoupe_98's Avatar
only real difference is that the wiring is alittle different on the back . also i have a 98 dash wire harness already wired for integra cluster that i will sell
Modified by EKlscoupe_98 at 7:12 PM 5/20/2007
Old May 22, 2007 | 04:46 AM
loverboy's Avatar
Default Re: ITR gauge cluster swap into civic 96 coupe (EKlscoupe_98)
Do u guys shure it doesnt matter which gauge cluster u choose according the Itr engine year u swap ?
So there is no reason to buy the 98-01 cluster (150$-300$) instead of buying the 96-97 cluster (80$-150$) ??
Why there is such a difference in the prices ?
Old May 23, 2007 | 09:27 AM
loverboy's Avatar
loverboy
Jul 1, 2009 02:18 PM
hype_R
Apr 8, 2008 05:35 PM
utn
Honda Civic (2001 - 2005)
Nov 12, 2007 01:48 PM
BlueIntegraBoy
Aug 10, 2006 06:05 PM
dawrenn
13
Mar 23, 2005 11:50 AM
