Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
will 01-03 shocks fit 04-05 ?
Old May 17, 2007 | 11:06 PM
Youngcity's Avatar
Default will 01-03 shocks fit 04-05 ?
planning to buy tokico HP gas shocks/struts but ive search and only found them for 01-03 just wondering if anyone has put them on or if they will fit thanks
Old May 18, 2007 | 12:31 AM
mrtrinh's Avatar
Default Re: will 01-03 shocks fit 04-05 ? (Youngcity)
you have to drill out the knuckle bolts from 14mm to 16mm. why don't you just buy the application for 04-05
Old May 18, 2007 | 12:58 AM
Youngcity's Avatar
Default Re: will 01-03 shocks fit 04-05 ? (mrtrinh)
b/c im planning to buy them off someone who has the 01-03.... what are the knuckle bolts? pics if you have and thanks
Old May 18, 2007 | 04:36 AM
bioweapon's Avatar
Didnt they change it from 14mm to 16mm in 03? All blues that i have seen have been for 01-02, and 03-05. So if you are getting them off an 03+, you should be fine.
Old May 18, 2007 | 09:27 AM
toyomatt84's Avatar
Sanji
Default Re: (bioweapon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bioweapon &raquo;</TD></TR><TR><TD CLASS="quote">Didnt they change it from 14mm to 16mm in 03? All blues that i have seen have been for 01-02, and 03-05. So if you are getting them off an 03+, you should be fine.</TD></TR></TABLE>
They changed the two hub mount bolts to 16mm, which shouldn't be a big deal at all. Grab a drill, and a 16mm drill bit.
micah_m
Suspension & Brakes
21
Feb 25, 2010 12:44 PM
tr0gsta
Aug 9, 2007 08:06 AM
Yellow Dragon
Honda Fit
Mar 8, 2007 03:46 AM
pumpkyn
15
Mar 24, 2006 12:53 AM
dgdarien
11
Jan 3, 2004 07:24 PM
