Cat bolts rusted on
Old May 17, 2007 | 09:36 PM
MilanoLude's Avatar
Default Cat bolts rusted on
Tried breaking the bolts loose on the cat to install a new header and they've got a large amount of rust on them. I tried using a 13mm socket and it's too small, however a 14mm seems like it has a lot of play.
I suppose they're rusted so much that they're between sizes. Are they supposed to be 13mm on a '92 H23?
Old May 17, 2007 | 10:41 PM
MacONE's Avatar
Default Re: Cat bolts rusted on (MilanoLude)
i would jus use a die grinder to take that off....
Old May 17, 2007 | 11:12 PM
MilanoLude's Avatar
Default Re: Cat bolts rusted on (MacONE)
I think that's what I might have to do. I was hoping that was going to be my last resort. But I ended up rounding one off anyway, it's obviously not 14mm lol.
They're 7 bucks a piece from Honda, so I didn't want to have to replace them. I should be able to use some bolts from Home Depot though right? They're just gonna rust again anyway.
Old May 17, 2007 | 11:15 PM
93sivtec's Avatar
use a standard socket,they are usually right inbetween mm sizes,u might be able to fit a 5/8 on there or something.Or sombody could have replaced the original bolts with a standard size.
Old May 17, 2007 | 11:35 PM
MilanoLude's Avatar
Default Re: (93sivtec)
Thanks, but 5/8 is too big. I think a 17/32 socket might work, but I can't find one and it's pretty late now. I'm just going to cut them off and replace them with some bolts from a hardware store.
Hopefully that works out.
Old May 18, 2007 | 01:27 AM
zirac50's Avatar
Default Re: (MilanoLude)
go to muffler shop and show the nut sometimes they give you one for free.
it got mine off using butane torch
Old May 18, 2007 | 04:30 AM
Maharajamd's Avatar
Default Re: (zirac50)
^ torch for the win.
Acidcrakker
Mar 3, 2008 08:46 PM
kornerk12
Nov 21, 2006 09:59 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
f1uxx
Apr 23, 2003 12:40 PM
SamC
Feb 28, 2002 07:37 AM
