Tire size selection for 17's
I was planning on getting some 16x7 Konig Heliums for my DB7 but yesterday I found a set of wheels I liked more but the smallest size they had was 17x7... I have acouple of quick questions... Alot of people recommended getting 205/45/16 for the Heliums so im thinking of just getting the same size but in 17"s... will that be fine? or should I go with a bigger tire? For the people with 17" wheels could you post your tire sizes? also will a 42mm offset fit on my DB7? The Konigs had a 40mm offset so I know it would fit but im not sure how much a 2mm diffrence would make but I rather be safe than sorry before I order them because I plan on getting a Koni/GC setup from Weksos soon and I wanna drop my car a considerable ammount... basically I wanna tuck the tires in the wheel well a little bit... any info/thoughts are appreciated. Thanks!
Also do you guys think I could go with 205/40/17? because it seems that that size has more of a selection that the 205/45/17.
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING »</TD></TR><TR><TD CLASS="quote">
What size tires should I get?
<FONT SIZE="4">The proper size depends on your car, not just the wheels you are using.</FONT>
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16
<FONT SIZE="4">For an Integra or '97-00 Civic, the following sizes are usually best:</FONT>
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16
<FONT SIZE="4">17" - 205/40/17</FONT>
It says:
13" - 175/70-13
15" - 195/50-15
16" - 205/40-16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparkman »</TD></TR><TR><TD CLASS="quote">Where do you find those sizes?</TD></TR></TABLE>
http://www.tirerack.com
http://www.vulcantire.com
These places would be a good start.
