B18B1 in 91 CRX - Timing???
Old Jun 1, 2002 | 02:16 PM
VTECVillain's Avatar
Default B18B1 in 91 CRX - Timing???
I swapped a 96 B18B1 into my 91 CRX DX. I used all non-OBD components - Distributor, ECU, and injectors. I can't get the timing set to the red mark at 16 BTDC. The distributor is set all the way back as far as it will go and it's about 2/3 the way between the red and white marks. I was wondering if it's the distributor holes not opened enough to go the extra distance or if the B18A1 has the marks on the crank pulley slightly different to where I would actually be over the red mark?
Old Jun 1, 2002 | 06:36 PM
ionic_slim's Avatar
Default Re: B18B1 in 91 CRX - Timing??? (VTECVillain)
your timing might be off by a teeth...check it at tdc.
Old Jun 2, 2002 | 03:15 PM
StorminMatt's Avatar
Also it is possible that the base timing is different with an early PR4 than a P75. This is what you get for using the wrong ECU.
Old Jun 2, 2002 | 06:09 PM
Jared's Avatar
Default Re: B18B1 in 91 CRX - Timing??? (StorminMatt)
Base timing is not different. It sounds like either you arent shorting the ignition timing set plug or you have a timing belt that is off.
Old Jun 3, 2002 | 07:10 PM
Default Re: B18B1 in 91 CRX - Timing??? (Jared)
It's possible that I'm not setting it right. All I did was hook up a timing light and used it to adjust the timing. It seems to run fine but I don't think it's exact. What is the timing set plug? Or better yet, what is the proper way to set the timing?
Old Jun 3, 2002 | 08:27 PM
Doodoo's Avatar
Re-do everything timing related. Return the crank to TDC, make sure the cam gears are at TDC. Put the top arm of the distributor in the middle. It should work out.
hmtcrxsir
Apr 10, 2017 08:01 AM
jlk16188
17
Jul 1, 2014 02:17 PM
mrmilitaryguy
Mar 5, 2008 12:24 PM
3rdGteg
Dec 1, 2002 08:15 AM
rioninja
Aug 4, 2001 05:48 AM
