Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 civic si, turn signal/blinker/flasher relay?
Old May 17, 2007 | 06:53 PM
pmafia's Avatar
Default 2002 civic si, turn signal/blinker/flasher relay?
Hey i have a 2002 civic si, 2 door, I have one problem today, when i pressed the keyless entry on my compustar remote usually the 2 front flashers flash, however only the one on the right flashed and the one on the left did not turn on. When I put on my hazards the light works fine though... or the turn signal, just not when i use my keyless now, I am wondering what could be the problem. THe blinker or flasher relay? Thanks
Old May 17, 2007 | 07:09 PM
EM2ner's Avatar
Default Re: 2002 civic si, turn signal/blinker/flasher relay? (pmafia)
1. Wrong Forum
2. Prob the bulb Considering the keyless is hooked up to your parking lights and the bulbs are double filament one is for turn-signals and one is for parking lights??
Old May 18, 2007 | 04:38 AM
bioweapon's Avatar
He's not in the wrong forum at all.
Canadian Si = American EX.
American Si = Canadian SIR.
Are your parking lights working on both sides when you turn your lights on?
Old May 18, 2007 | 08:04 AM
pmafia's Avatar
Default Re: (bioweapon)
that is the car I have, its actually an EX I had it imported from New York.
Also, parking lights just level 1 on the switch, then yes, again my right turn signal turns on, but the left doesn't...
So is the light burnt out? Wiring problem? Up here in Toronto we have a store called Canadian Tire, kinda like walmart they have a garage, buddy told me it could be a wiring problem, but I dont know and I dont want to pay some mechanic 100$ to replace a light bulb for me. I really appreciate your help guys.
Thanks.
Old May 18, 2007 | 08:27 AM
bioweapon's Avatar
Whatever you do, do not take your car to crappy tire. They will probably attempt to tell you that your headlight fluid is low. Im from niagara falls man i know all about them. Id quickly try swapping bulbs from your right side to see if thats the problem. Could also be the relay, but check the bulbs first cause its way cheaper and easier.
Old May 18, 2007 | 08:51 AM
EM2ner's Avatar
oops... i didnt see were you were from.. im sorry i just seen the title saying 2002 Civic SI
I would get a wire tester and see if you are getting power to the light bulb harness to determine if its the bulb,relay,short,switch....etc
Old May 19, 2007 | 10:09 AM
pmafia's Avatar
Default Re: 2002 civic si, turn signal/blinker/flasher relay? (EM2ner)
Thanks for the reply guys, so to replace the bulb, do you know if I have to take out the bumper as well? I had a 2000 civic before and I had to take off the bumper is this the case for these models?
Old May 19, 2007 | 10:41 AM
i-VTEC_DOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmafia &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply guys, so to replace the bulb, do you know if I have to take out the bumper as well? I had a 2000 civic before and I had to take off the bumper is this the case for these models?</TD></TR></TABLE>LMFAO you didnt have to take off your bumper lmao u just pop the pins in the wheel well and pull the lning back and ur there lol hahahahahahahhaa all that hassle when all you needed was a flathead screwdriver
well onwards and upwards.. ur car has dual filament bulbs and the filament that blinks probly just burned out.
Old May 19, 2007 | 11:01 AM
pmafia's Avatar
ya i know it was a hassle so there was just two screws that I unscrew and replace that orange bulb? Thanks guys
Old May 19, 2007 | 11:18 AM
ya pretty much lol sorry to burn you dude but ummm.. owners maual clearly states that u go thru the wheel well to change the turn signal bulb. and it would be sensless to make a car where u gotta take a bumper off to change a little itty bitty bulb. unless u dont have an owners manual which is a wamby bamby from the start. and theres online owners manuals too
Old May 19, 2007 | 03:30 PM
pmafia's Avatar
ya i know lol,
i have an update, i punched the headlight and it turned back on, only temporary it went back out again now im thinking it could be a wire or lose bulb? also the parking light went out now, the light in the middle its clearly burnt, its basically black now. this is all from the same side... so now i know i have to replace 1 bulb 100% what you guys think about the turn signal/parking light now?
Old May 19, 2007 | 08:27 PM
hmmmm wires gotta messed up or loose.. most likely from the back of the connector is where it usually has problems.. nothin a little elec tape cant fix
rawrjaay
Aug 24, 2022 02:38 PM
boostjunkieee
Dec 12, 2012 05:52 PM
ohbuckeyes
Dec 16, 2011 10:59 PM
pmafia
May 17, 2007 06:34 AM
