exhuast question
Old May 17, 2007 | 06:40 PM
CiviCVuE's Avatar
Default exhuast question
I am running a b18c in a 98 civic coupe and the stock exhaust doesn't line up with the headers, any answers would be greatfull. searched but no luck on this subject, thanks
Old May 17, 2007 | 06:42 PM
nix94delsol's Avatar
grab a b series exhaust header , someone correct me if im wrong but all the b series EH's are direct bolt
Old May 17, 2007 | 06:43 PM
Mr.EM1_EK's Avatar
Default Re: (crx4life90)
yeah they are all the same
Old May 17, 2007 | 08:44 PM
CiviCVuE's Avatar
Default Re: (Mr.EM1_EK)
well how about this i have a b16a header will that work
Old May 17, 2007 | 08:47 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (CiviCVuE)
The length of the piping for the cat is differen't between b18 and b16 headers. That might be the only difference you run in to. Also the height under the car is differen't because b18 blocks are typically taller than b16 blocks.
Old May 17, 2007 | 10:18 PM
RCautoworks's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">The length of the piping for the cat is differen't between b18 and b16 headers. That might be the only difference you run in to. Also the height under the car is differen't because b18 blocks are typically taller than b16 blocks.</TD></TR></TABLE>
There about 2mm taller, not a huge difference. Besides the length of them, on occasion I see some flanges being reversed, where the right side is lower when it should be higher, or vice versa. All depends on what header you run, aftermarket or stock. And all depends what your exhaust setup was for.
Mr. DeOro
11
Aug 6, 2009 05:13 PM
AtomicEG
Mar 10, 2008 04:20 PM
HbDrIvEr
Jan 28, 2007 07:04 PM
ex94vtec
Jan 23, 2006 06:51 AM
BigZ88
Dec 7, 2003 12:29 AM
