Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Can anyone give me an idea?
Old May 17, 2007 | 09:25 AM
kb1ioq's Avatar
Default Can anyone give me an idea?
Hi all,
I'm new posting here, but I have a one month old 07 civic ex that I just bought. I want to change the gauges and stereo and all the color stuff on the dash to the sweet orangy-red color of the si. Is that possible?
Also what other mods can I do for the ex that will increase performance without spending so so much, I have to keep making my car payments so it can't break the bank.
Thanks so much,
Matt
Old May 17, 2007 | 09:28 AM
Type X's Avatar
Default Re: Can anyone give me an idea? (kb1ioq)
I dont think anyone has swapped out the clusters yet....
Personally it SHOULD be plug and play (with the exception of an auto harness to manual that might not plug in) if your even auto
but you run the following issues....
1 The Si cluster has already in the cluster which visibly is a little ricey.
2. The radios you can swap IF you are going from an EX to an Si, a lower model you will run into AMPLIFIER issues.
3. See 1&2
This is all based on assumptions and having the car pulled apart numerous times.
but I believe i'm 99.9% right.
Old May 17, 2007 | 09:30 AM
kb1ioq's Avatar
Default Re: Can anyone give me an idea? (Type X)
I have the top of the line loaded EX with everything but navigation. I believe they have the same stereo set-up and everything. It is a 5-speed manual. I'm also new so I don't know car-tech talk . In the older civics I know you could change the backlighting color in the gauge cluster and stuff without an issue, it was just a color palette or something of that nature.
I don't know with the new ones.
Old May 17, 2007 | 09:54 AM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb1ioq &raquo;</TD></TR><TR><TD CLASS="quote">I know you could change the backlighting color in the gauge cluster and stuff without an issue, it was just a color palette or something of that nature.
I don't know with the new ones.</TD></TR></TABLE>
With the older civic's its just a matter of changing out the bulbs... on the newer civic's you'd have to swap out the entire unit(s) -- Radio, cluster, speedo, etc. Totally not worth it unless you're getting the stuff for super cheap IMO.
Inexpensive mod for starters would be some springs or an intake/exhaust.
Old May 17, 2007 | 03:57 PM
Ouija's Avatar
Suspension first. If it rides like **** there's no point in going faster/harder.
Old May 18, 2007 | 09:49 PM
yuning83's Avatar
tint first
Old May 18, 2007 | 09:53 PM
seed2harvest's Avatar
* B A N N E D *
i honestly like the blue better than my red gauges.... maybe, just a little, not a lot,. but i do, but dont, kinda sorta, yeah fer sure. haha, take that.
Old May 19, 2007 | 05:09 AM
televascular's Avatar
Default Re: (seed2harvest)
I don't know for sure, but I don't think the blue/red clusters are an easy swap. Keep in mind that the Si has a redline shift indicator light... I'm no electrician, so I dunno if that poses a compatibility problem. The wiring might be different.
As for cheap performance mods, get some front camber bolts (~$30). A touch of negative front camber will do wonders for cornering performance.
Old May 19, 2007 | 05:57 AM
kb1ioq's Avatar
Default Re: (televascular)
I've decided to stay with the blue, my fiance also told me she liked the blue better than the orangy/red also. Now I just need to decide what to do for some performance upgrades....
Old May 19, 2007 | 07:07 AM
* B A N N E D *
good call.
he brings a good point too, about having the red.... its got the little shift light. i think the blue is sexy though.....
Old May 20, 2007 | 06:08 PM
20strong's Avatar
I miss the blue in the Ex. But I love my Si.
stopspazinout
11
Jun 8, 2011 10:29 AM
95EGciv
Mar 8, 2009 02:39 PM
JohnnyEF
17
Oct 6, 2006 07:27 PM
remborsky
14
Sep 20, 2004 09:44 AM
Chicken SOup
Jan 1, 2002 02:24 PM
