Heat won't turn off!
Well summer is coming I thought my car was flaming hot then I noticed that my heat is on no matter what I do with the blower control. It stays on, its on a moderate push but you feel the difference when you close the windows and feel the heat coming out. Is one of the lines disconnectedc
Your climate selector slider thingy is mechanically connected to a valve just on the outside of your firewall (right in the middle). That valve should open and close as you move the 'thingy' back and forth.
If it doesn't, then most likely there is an anchor clip that is screwed to the bottom of the climate control unit, above the radio, that has probably come loose. Take a few minutes to get to, but pretty easy fix.
Might not be this, but is a good place to start.
Is there a certain fuse I can pull to do this? Haha I am just trying to take the easy way out of it because work sucks and community service for graduation (20 hours before tuesday) has been ripping me apart.
lived dreams
Mar 4, 2009 03:25 PM
zerogravitycrx
Dec 6, 2004 01:34 AM
technine
Sep 16, 2002 01:28 PM
