dohc zc stuff + t3 turbo's, cast manifold, teg bezel
Old May 17, 2007 | 06:38 AM
doubleA's Avatar
Default dohc zc stuff + t3 turbo's, cast manifold, teg bezel
*UPDATED*
I ran the dohc zc last year in my crx and Ive got a bunch of parts laying around for it that I'm not going to use. Feel free to make offers.
#1 jdm dohc zc head with valvecover. $40
#2 SOLD!!! d16a1 head with port polish, decked aftermarket valvesprings and polished valvecover. This head will bolt to either the 88-89 integra or the zc blocks.
#3 set of dohc zc cams. these do not come with cam gears. when I got the motor it had B series gears on it which will work if you know how to set them. Cams are in great contition with no rust, kept clean. $25
#4 set of srt-4/ pt cruiser/ dohc zc ARP head studs. I bought these new from tuner toys. they are perfect for the zc. Used once, comes with all hardware and I think I still have the box also. $50
#5 Tappped dohc zc oil pan $20
#5 Real honda oil pump, fits d16a6 or the sohc or dohc zc motors. Bought from majestic honda and has one summers use. still perfect condition. $20
#6 real dohc zc transmission. with intermediate shaft. close ratio gears, no grinds, no leaks. will work with any d series motor and you'll get to use equal length axle shafts just like the B series guys. $120
There are a few other misc things like the oil cooler from the back of the block and ther thermostat housing and timing belt tentioner and water pump if anyone is interested. Also have two great condition d16a6/zc crankshafts and a new dohc zc headgasket.
Added items...
T3 .48/.60 turbo has a lil shaft play but runs good with no smoking. Im looking for $125 for this one.
T3 .63/.60 I ran this all winter with no problems, great turbo. Im looking for $150 for this one.
ECU's One pg7 wich is obd0 d16a1/dohc zc
One p75 obd2
B-series blox manifold. SOLD!!!
Two sets of zc spark plug wires, one ngk one msd $20 each
integra dual gauge pod bezel.. whatever.
EF/ED mirrors
msd rpm switch $20
Sohc aluminum flywheel. Needs new friction plate. $15
ED/EF gauge pod. $15
Aem intake tube, 92-95 civic. You can see where it was rubbing. $20
Ill get some prices up later.. For now just make me an offer. everything is located in MN.
Modified by doubleA at 8:29 AM 6/7/2007
Old May 29, 2007 | 11:47 PM
teknohatchie91's Avatar
Default Re: dohc zc stuff + t3 turbo's, cast manifold, teg bezel (doubleA)
pm'd
Old May 31, 2007 | 12:31 AM
jdls93's Avatar
pm'd
Old Jun 5, 2007 | 04:49 PM
vtec-763's Avatar
pm'd
Old Jun 7, 2007 | 07:32 AM
doubleA's Avatar
Default Re: (vtec-763)
All pm's replyed and new items added
Old Jun 7, 2007 | 12:10 PM
ProJectCvic's Avatar
Default Re: (doubleA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleA &raquo;</TD></TR><TR><TD CLASS="quote">T3 .63/.60 I ran this all winter with no problems, great turbo. Im looking for $150 for this one. </TD></TR></TABLE>
what type outlet? I can't tell from the pictures.
Old Jun 7, 2007 | 04:42 PM
traitorzxiong's Avatar
PM sent
Old Jun 8, 2007 | 06:00 PM
doubleA's Avatar
Default Re: dohc zc stuff + t3 turbo's, cast manifold, teg bezel (traitorzxiong)
Both of the t3's are the ford five bolt outlet.
90dohczccrx
Oct 11, 2010 05:04 PM
krysted9354
May 17, 2009 09:47 PM
tyler100
Aug 13, 2008 06:25 PM
Dc2 Joe
Apr 3, 2006 07:42 PM
RACEPAK
May 18, 2005 11:03 PM
