88-89 cluster swap to a 90-91 cluster. please help!!
Old May 16, 2007 | 07:52 PM
ant$missShift's Avatar
Default 88-89 cluster swap to a 90-91 cluster. please help!!
OK im putting a 90-91 si cluster in my 89 si crx from what i can find i just need to repin the colors to where they where on the 90-91 clips.. problem is the only cluster swap info and pinouts i can find ( the vti cluster swap info in the faq section) show that clip C (lil blue clip) only has one wire going to it . and on my 89 cluster i had 4 wires going to it and on my 90 91 clips has 5 wires to it.. i know this has to be a pretty common swap. some more info woudl help or exact pin outs of every wire.........
someone help me out pleaseeeeeeeeeeeee!
thanks alot.
Old May 16, 2007 | 08:07 PM
madmanmulligan's Avatar
Default Re: 88-89 cluster swap to a 90-91 cluster. please help!! (ant$missShift)
what i did was repin one of the clips on the dash harness of the 91.. there were 4 wires left over and if you look on the hazard switch thats wired directly to the fuse box there are the same 4 wires so i assume you connect those but on the hazard switch there are 2 extra wires a yellow and a green with a blue stripe anyone know what there for?
Old May 16, 2007 | 08:40 PM
bumpo
Old May 16, 2007 | 09:11 PM
julioboostamante's Avatar
im alsmot certain that the mani 2 plugs are the ones that work your cluster. Then again i might be wrong.
Old May 16, 2007 | 09:43 PM
downest's Avatar
Default Re: 88-89 cluster swap to a 90-91 cluster. please help!! (julioboostamante)
If you don't know, don't reply, too many people are ******* up easy stuff because of false info that's out there.
Here's a pic with each of the plugs on both the 88-89 and the 90-91. I've used this a couple of times and it works. The plugs are very easy to depin with a small screwdriver.
Old May 16, 2007 | 10:02 PM
Deetz's Avatar
Crazy Honda Guy
^^ Thats a very good pic, thanks for the post!
Old May 16, 2007 | 10:55 PM
downest's Avatar
Default Re: (Deetz)
It's not mine, I got it on here a long time ago. I condensed all four pics and saved it because images tend to disappear. If anyone needs it in the future PM me, my webspace at school will disappear soon as I graduated recently.
Old May 23, 2007 | 05:21 PM
fiji_crx's Avatar
Default Re: (Deetz)
would u know for the japan civic 1990 b16 colour wire?
Old May 31, 2007 | 05:30 AM
Default Re: (fiji_crx)
i wired it all up but for some reason my brake light stays on but everything else works correctly.
Old Jun 6, 2007 | 05:09 PM
Default Re: (ant$missShift)
are all the Ef's the same in color codes for those 2 plugs? I mean the hatchback, 4 door, wagon and CRX? If so then i made a chart as to what plugs go where if your going from a 88-89 cluster to a 90-91.
Old Jun 6, 2007 | 09:03 PM
143MYVTECEF's Avatar
Default Re: (julioboostamante)
Ive posted the same problem but my question was what was the third blue plug on the back of the manifold for?
Old Jun 8, 2007 | 03:00 PM
Default Re: (143MYVTECEF)
manifold or the back of the cluster?
Old Jun 8, 2007 | 06:02 PM
Sorry i meant back of the cluster..
jdmef69
Mar 30, 2013 05:42 PM
BIGef
Jun 23, 2012 09:05 PM
Wuffer
Jul 30, 2007 05:14 PM
ef-b16sedan
Jul 7, 2006 01:21 PM
88rexboy
Mar 31, 2004 08:42 AM
